ARP head stud install. 1by1 the right way
Old Feb 6, 2007 | 11:13 AM
tweakdsm's Avatar
check evomotto.com, I did not pulled the head to install HS, i did 85ft.lbs HD thats with 272/272 hks cams, I put about 20,000 miles on the car allready. Just install like it shown, I call it spider web, form center to outside , GL
Old Feb 6, 2007 | 11:17 AM
mac_05evo's Avatar
Originally Posted by evodan2004
ok now how about the way you trq them down. do you just go right to 75 80 foot pounds or do you got to loosen tighten loosen tighten and how should that be done????
I tightened progressively, I think I did it 5 times. I started with 45 ft lbs, loosened, 55 ft lbs, loosened, 65 ft lbs, loosened, etc up until 85 ft. lbs. The stud itself just goes into the block and shouldn't be tight at all just snug it up a little bit with the provided allen wrench.
Old Feb 6, 2007 | 11:52 AM
EvoDan2004's Avatar
awsome guys. thanks
so 1 stud at a time
start from middle to outside like the graph just starting from 10
trq 1 stud at a time. 5 times
45, 55, 65, 75 final 85 then move on to next stud.
Old Feb 6, 2007 | 11:53 AM
EvoDan2004's Avatar
oops 1 more thing. do i aply the lube arp supplyed me with to bouth ends of the treads and about how much??
Old Feb 6, 2007 | 12:19 PM
Kerr's Avatar
Fomer Vendor
This thread seems to be back and forth a bit on how to exactly do this. When you do the 1 by 1, you take out the stock one, than replace it with the new one. You don't take them all out at the same time. Hence 1 by 1.
The first post made it seem that you were saying to take them all out at the same time, but then later you were talking about it like you were doing the true 1 by 1. I just wanted to clear this up.
Old Feb 6, 2007 | 12:21 PM
EvoDan2004's Avatar
my bad. i did mean 1by1 from the begining. sorry forthe messup.
but where do i apply the lube arp supplyed me with. just on the nut side or bouth sides of the stud and about how much.
Old Feb 6, 2007 | 12:32 PM
Curt@MrLed's Avatar
Former Vendor
just apply a little and rub it into the threads with your finger.. put the lube on the nut side.. also you will do a little prying to get a couple out if not changing the cams at the same time.. it can be done though.. no need to replace h.g. if done the way you were told. you dont have to do it in 5 steps, just 3.. lastly some people, (Tuners go up 90 ft. lb's also sometimes, search this.) will go 90 ft. you dont need it. and most important, check there tightness at 50 miles, 300 miles, 1000 miles and if they havent moved then check again at 3000 miles.. if they loosen no worry, just tighten them. if they havent moved your done.. do not forget to recheck them at these miles.. i have had a couple come loose, after some miles.. its not hard to pull the v.c. and check, besides its small ins. and get a good torque wrench..
Old Feb 6, 2007 | 12:34 PM
EvoDan2004's Avatar
im going to 80foot pounds.
ok here i go. i got all my info. see how she gos. thanks everyone.
Old Feb 6, 2007 | 12:38 PM
Curt@MrLed's Avatar
Former Vendor
updated my post.. lastly the factory uses bolts not studs. they cant be reused, when you pull em throw them away..
Old Feb 6, 2007 | 12:44 PM
hondafan's Avatar
or if you know anyone with a honda, give em to them. they work great to thread into the block to hold it on an engine stand!
Old Feb 6, 2007 | 02:39 PM
Curt@MrLed's Avatar
Former Vendor
i stand corrected..
Old Feb 6, 2007 | 02:59 PM
evo150's Avatar
keep us updated
Old Feb 6, 2007 | 03:29 PM
EvoDan2004's Avatar
ok guys im done. everything went very well. now lets see how it hold up.
Old Feb 6, 2007 | 03:39 PM
EvoDan2004's Avatar
now should i let the car get a few miles on it and recheck them or no???? they are all trqed to 80foot pounds
Old Feb 6, 2007 | 03:43 PM
EVOlution561's Avatar
great!!!! i'm looking to do this soon.
