ARP head stud install. 1by1 the right way
Old Feb 6, 2007 | 03:58 PM
  #31
Kerr's Avatar
Fomer Vendor
Originally Posted by evodan2004
now should i let the car get a few miles on it and recheck them or no???? they are all trqed to 80foot pounds
I would say follow Farmers advice; check them at 50 miles, 300.... Mainly because everyone dogs the 1 by 1 method so much.
Old Feb 6, 2007 | 09:32 PM
  #32
EvoDan2004's Avatar
ok well today i beet the **** out of the car. seems as of right now it is holding up.
thursday im going to pull the cover off and check the trq settings again to make sure everything is still in good spec
Old Feb 6, 2007 | 09:39 PM
  #33
dudical26's Avatar
please keep us updated, check all the way around the head gasket, its pretty common for on oil leak to occur on the back of the motor between the block and the head.
Old Feb 6, 2007 | 09:43 PM
  #34
EvoDan2004's Avatar
ok. will do
but as of right now. nothing
Old Feb 6, 2007 | 09:53 PM
  #35
bullfrg's Avatar
Exactly what mine is doing, wish the previous owner wouldn't have changed them.
Will pulling the VC and retorquing them help this?
Old Feb 6, 2007 | 09:55 PM
  #36
whitersevo's Avatar
your head gasket will be fine, until they become loose because you didnt take off the head..
Old Feb 7, 2007 | 12:18 AM
  #37
03whitegsr's Avatar
Torquing the ARPs to 85+ ft-lbs basically makes them a 1 time use item as it stretches them into yielding.
I've done the 1 at a time replacement on a 2G DSM. The car made 450 WHP on race fuel and 380 WHP on pump gas daily driven. I'm not too sure they really needed to be replaced at that level though. The stock bolts are reasonably good. I plan on just leaving them alone on my Evo until I lift the head and have to replace them. When I do them, they will be L-19 studs and not ARPs though.
Old Feb 7, 2007 | 04:51 PM
  #38
Curt@MrLed's Avatar
Former Vendor
it wont hurt..
Old Feb 7, 2007 | 05:19 PM
  #39
Exciting News's Avatar
ok guys im done. everything went very well. now lets see how it hold up.
give it a few months. that's how long it took for mine to start leaking.
Old Feb 7, 2007 | 05:37 PM
  #40
nightwalker's Avatar
I don't care what you guys do, the one by one method is a gamble. Ask any knowledgable mechanic. Some of you just got lucky. I would do it the right way if I were doing mine.
Old Feb 7, 2007 | 05:40 PM
  #41
Kerr's Avatar
Fomer Vendor
I have a question, what else is done when taking the head off? Meaning, what more do you do then just using the 1 by 1 method?
Old Feb 7, 2007 | 05:41 PM
  #42
Curt@MrLed's Avatar
Former Vendor
that makes no sense.. a head gasket doesnt help hold the head down..
Old Feb 7, 2007 | 05:43 PM
  #43
fitbikedominick's Avatar
Im just going to do cams valvesprings and headstuds all at the same time so my engine dosnt break good luck with the 1 by 1 method i herd it was a bad idea but 90% of people talk out of there butt any how.
Old Feb 7, 2007 | 05:46 PM
  #44
Curt@MrLed's Avatar
Former Vendor
some people think that changing a perfectly head gasket with a new head gasket is what has to be done.. its one of things that either the person has no idea what there talking about, or when they did a stud change they didnt do the job right, or didnt recheck em.. on v8's i would pullt he head when changing too studs, but that was because the heads were easy to pull, and some of the studs went through water passages, so that ment you would have to clean the threads out, so there wasnt any leaking.. our motors dont have studs that are in water.. other dsm motors did..
Old Feb 7, 2007 | 07:25 PM
  #45
Kerr's Avatar
Fomer Vendor
So are you saying that when people pull the head to do the studs, they change the head gasket and thats it? I thought they would literally pull the head, swap the studs and put the head back on, done. Thats why that makes no sense to me when comparing the two.
Even if they just change the head gasket and put everything back together it still doesn't make a lot of sense, just seems to make a lot more work.
