gt35r vs. 50trim (debate!)
Old Apr 2, 2007 | 10:13 AM
  #91
KOEvo's Avatar
Originally Posted by evodave
w/ cams ,ems, alky injection on 93 octane with stock motor /intake manifold (besides the cams and headbolts compared to your mods) i made 558 awhp SAE corrected at 29-30psi so i would say gt35r w/.63 backside....good spool and big power. Rev the stock motor to 8500rpms at most ....i did or you can go 8200 rpms which is where most people say is max and you will have a nice big powerband. BTW i drove around with about 500-510 awhp and that was enough to trap 129mph
Dave
'Nuff said. I would do the exact same...
Old Apr 2, 2007 | 10:14 AM
  #92
crcain's Avatar
Originally Posted by High_PSI
Yeahbut don't forget that you are in Colorado, abotu a mile up and with that 20% less air making yoru GT35R lag way more. Down here at Sea Level I have seen a GT35R fully spool at 4300RPM's in 3rd gear on a IX, it was VERY fast and VERY responsive. I couldn't believe it.
Did you ever read the "GT35R Spoolup Answers" thread? I'm at sea level, built 2.0 litre, AMS GT35R... let me check my data log....
18 psi at 4900 rpm
28 psi at 5500 rpm
If I recall those numbers were fairly typical for a 2 litre. Saying GT35R spools at 4300 rpm.... well it seems crazy to me and I'd probably need to see a datalog to prove it.
Old Apr 2, 2007 | 10:49 AM
  #93
KOEvo's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=212769
Old Apr 2, 2007 | 10:53 AM
  #94
Genesis8's Avatar
50trim and meth is the way to go.....
Old Apr 2, 2007 | 11:24 AM
  #95
High_PSI's Avatar
18 psi at 4900 rpm
28 psi at 5500 rpm
MIVEC + COSWORTH CAMS =
Old Apr 2, 2007 | 12:48 PM
  #96
crcain's Avatar
No offense but if you think Mivec and Cosworth can give you 1000 RPM in spool.... you are crazy! Here is a thread with dozens of respected posters saying full spool on a 2 liter is after 5k rpm.
https://www.evolutionm.net/forums/sh...poolup+answers
You saying your friend reached full boost at 4300 is just ridiculous. Even with a stroker your only supposed to get back maybe 500rpm in spool.
I'm just more likely to believe pages and pages of solid poster's data logs than one guying saying his friend did X or Y.
Old Apr 2, 2007 | 01:27 PM
  #97
High_PSI's Avatar
OK, I was only in the car but what do I know, I mean it's not like he showed me his logs from his AEM or nothin' .
Seriously, he was only running 28PSI, from a rollon it was QUITE impressive, full boost was way before 5000 RPM's. Maybe you need a tune? MIVEC does help considerably in the spoolup dept. as well.
Old Apr 2, 2007 | 04:15 PM
  #98
crcain's Avatar
So you were staring at the boost guage... and the moment you saw it read 28 PSI, you looked at the tach and it read below 5k? Just curious because I can promise that is hard to do because the car is moving at that point. Funny how first you said 4300 full boost, and now your saying deffo under 5k.
I don't need a tune dude, I run Autronic and car was tuned by top UK tuner who flew here just for the tuning. So thanks for the advice though.
No need for us to argue though. Like I said, I'd prefer to believe the dozens of people that reported their logs than the claim of one person without real data.
Old Apr 2, 2007 | 04:21 PM
  #99
trinydex's Avatar
i think people should only trust boost logs. it's bad enough that a butt dyno depends on the person's ***. a crosseyed boost evaluation is just gonna compound the problem.
Old Apr 2, 2007 | 04:32 PM
  #100
crcain's Avatar
I agree and I would not blame someone for thinking the car is making boost earlier than it is. When I first drove my car with the GT35 I thought it felt great and not much laggier than stock. Then when I looked at the data logs later that night I was suprised to see it not reaching full boost until after 5k.
Old Apr 2, 2007 | 07:25 PM
  #101
Liqquid's Avatar
still like the 35r or did the logs change your mind? bet you still like it
Old Apr 2, 2007 | 07:40 PM
  #102
crcain's Avatar
At first I was like wow, what lag?
Then as I drove the car a bit more I was like hmmm, I do miss the car being more responsive. Basically the feeling of the GT35R in my opinion was exactly like you'd expect. It feels great to have all kinds of top end, but you miss the power down low too.
2.4 from Magnus is ordered now so hoping for best of both worlds.
Old Apr 2, 2007 | 08:03 PM
  #103
midwestmonster's Avatar
I think it really depends what you want to do with the car. I do not want to build my motor anytime soon or stroke it in the future. If you really only plan to run on pump gas, I believe the 50 trim is the way to go. You can make similar numbers with the 35r, but it will be more laggy. On race gas, it's a different story. You're probably giving up around 60 horsepower or so with a 50 trim. Still, with almost 500 at the wheels on my 50 trim, I have to say I can't imagine having/needing more power right now. I think you can't go wrong with either turbo. It just depends what your ultimate goals are.
Old Apr 2, 2007 | 08:05 PM
  #104
scorke's Avatar
Giving up 60 whp? Where are the 50 trims making 540whp?
Scorke
Old Apr 2, 2007 | 08:07 PM
  #105
What I meant is, the 35r will make about 60 more horsepower on race gas.
