Umm....Something happen, engine died
Old Feb 8, 2007 | 07:05 PM
scottatyamaha's Avatar
Timing belt slip.
Old Feb 8, 2007 | 07:07 PM
RoadSpike's Avatar
Originally Posted by Evoryder
rear o2 would not cause vehicle to die...just a cell.
Does the car crank? How'd it die? Did it struggle or just power down?
Its not the actual loss of the o2 which causes the car not to run its the short in the powered heating circuit which ko's the circuit.
Honestly i can't remember where the fuse is but if you want someone's similiar issue here you go.
https://www.evolutionm.net/forums/sh...e+ECU+location
Evo_Jay's Avatar
Originally Posted by scottatayamaha
Timing belt slip.
That is a possablity, i guess, car only has 20K miles, kinda early for the timing belt to be goin gout.
Old Feb 8, 2007 | 07:10 PM
RoadSpike's Avatar
Its been my experience that timing belts are more of a catastrophic failure than a simple slip
Old Feb 8, 2007 | 07:11 PM
TTP Engineering's Avatar
Your CEL fix pushed the rear O2 into the undercarriage, wearing the protective sheath from the wires and it shorted on the chassis. The fuse under the dash (7.5a) (brown) is likely blown and needs to be replaced. Remove the CEL fix and hammer the underside of the car to increase clearance where the wires will no longer contact the chassis.
Old Feb 8, 2007 | 07:12 PM
Nad1370's Avatar
How long ago was the walbro put in?
One of the possibilities could be a pinched sock that restricts fuel to the injectors.
Old Feb 8, 2007 | 07:30 PM
RoadSpike's Avatar
My bad so its the 7.5amp fuse not the 20amp
Old Feb 8, 2007 | 07:43 PM
Evo_Jay's Avatar
DING DING DING.. you have won a gift.
A EvolutionM.net lanyard
PM me your address and Ill send it out tomorrow.
Old Feb 8, 2007 | 07:44 PM
Evo_Jay's Avatar
No. Its a 20A under the hood. One of the "two" with and engine icon.
Old Feb 8, 2007 | 07:51 PM
RoadSpike's Avatar
I take it your up and running, good
I don't need a lanyard thank you though.
Old Feb 8, 2007 | 07:54 PM
Evo_Jay's Avatar
Word. Thanks for the help.
lol, I dont need the lanyard either.
Old Feb 8, 2007 | 07:57 PM
That short will blow either the underhood or the under dash 7.5a.
Old Feb 8, 2007 | 07:58 PM
RoadSpike's Avatar
Good info I'll keep that in mind the next time this shows up.
Old Feb 8, 2007 | 08:31 PM
dubbleugly01's Avatar
The Evom community at it's best!
Old Feb 8, 2007 | 08:52 PM
Evoryder's Avatar
most def!
