Umm....Something happen, engine died
Old Feb 8, 2007 | 06:35 PM
Evo_Jay's Avatar
So I had just finished installing a test pipe and a O2 fix. Let the car warm up, made sure there was no CEL. Went for a test drive, after the temp go to operarating point, I boosted once. Then i boosted again. The thrid time I boosted, my car just died.
No loose IC piping and nothing I can see.
The only mods are
walbro
MBC (set at modest 21)
test pipe
The ECU is running the stock ROM right now.
Any ideas??
Old Feb 8, 2007 | 06:41 PM
RoadSpike's Avatar
Check:
- Pinched o2 wires and short
- Check fuses
Old Feb 8, 2007 | 06:44 PM
Evo_Jay's Avatar
Originally Posted by RoadSpike
Check:
- Check fuses
Checked fuses
I think pinched O2 wire and/or a short, would just give a CEL, but in theory, the car would still run/start.
Old Feb 8, 2007 | 06:49 PM
RoadSpike's Avatar
Originally Posted by Evo_Kid
Checked fuses
The short according to previous posts has KO'ed the fuse to the ECU and thus prevented the car from starting let alone running
electricevo's Avatar
if you didnt turn your MBC down after installing you test pipe, you probly over boosted, as there is less back pressure. It probly blew an I/C pipe off that may not be immediatly noticeable, as the I/C hoses usually stay butted up against where they are supposed to be, just not tight with clamps.
Could have also been the LICP, be sure to check that as well
Evoryder's Avatar
rear o2 would not cause vehicle to die...just a cell.
Does the car crank? How'd it die? Did it struggle or just power down?
Old Feb 8, 2007 | 06:51 PM
Are you getting crank or nothing at all when you turn the key?
Evo_Jay's Avatar
Will check. WHich fuse does it exactly blow??
Old Feb 8, 2007 | 06:53 PM
Evo_Jay's Avatar
I didnt install a TBE, I installed a test pipe only.
I was watchin the boost gauge, it was 20-21 lbs
Checked all IC piping very thoughly, becuase I've had IC piping blew off before.
Old Feb 8, 2007 | 06:54 PM
Evo_Jay's Avatar
The car cranks. I was driving, boosting then it just died, dont even think it made a sound.
Car does not run.
Old Feb 8, 2007 | 06:56 PM
Evoryder's Avatar
You can crank it up...and fires, however, you cannot move.
this is gonna sound really stupid, but how much gas did you have?
Old Feb 8, 2007 | 06:57 PM
Evo_Jay's Avatar
Ful tank
Old Feb 8, 2007 | 06:58 PM
Evo_Jay's Avatar
It just cranks, no fire.
Old Feb 8, 2007 | 07:01 PM
Evoryder's Avatar
fuse.
coils
fpr
fuel pump
