evo 9 clutch job issue,
Old Feb 11, 2007 | 02:22 AM
coolguycooz's Avatar
OK what i want to know, is the evo 9 clutch set up exactly the same as an evo 8? like the throw out bearing its exactly the same and everything? i think my buddy had a problem with his throw out bearing setting itself, so i just want to know for tomorrows install. would suck to have to pull the tranny a 3rd time.
Old Feb 11, 2007 | 12:54 PM
anybody? i just want to know if the evo 9 is exactly the same as the evo 8.
Old Feb 11, 2007 | 01:04 PM
mcwop23's Avatar
yeah
Old Feb 11, 2007 | 02:03 PM
ries's Avatar
Im pretty sure the setup is the same (pressure plate, throw out bearing, flywheel, disc, etc...) but you might run into issues w/ the ACD...dont know if youll have to bleed it and/or pump it etc...
Old Feb 11, 2007 | 10:51 PM
t51splbb's Avatar
Yes,the both use the same clutches between VIII & IX and 5 speed/6 speed cars.
Old Feb 12, 2007 | 03:40 AM
well its 3:36 AM we started at 7:00 pm, it took us this long just to get the tranny to line up and go on to the motor,
does anybody have any advice for future refrence as far as lining up the tranny with the motor
anybody have any hints or techniques they use to get it to line up and go in super easy?
i mean we got it done, but but 8 and a half hours straight just to get the tranny to go on is ridiculous, we had a cherry picker, and multiple jacks and it was ridiculous,
we finally got it by having the chain between the hangers on the head, slid that chain over the middle of the cherry picker and hooked the tranny up to the cherry picker hook and kind of picked both up at the same time, then after screwing with it for 2 hours between the two of us we got it in.
anybody have any tips for future refrence.
also is there a write up on bleeding the ACD?
Old Feb 12, 2007 | 11:12 AM
Danny23's Avatar
Make sure you bleed that acd correctely!
Old Feb 12, 2007 | 11:15 AM
hondafan's Avatar
i use an engine hoist with 2 ratchet straps to hold the tranny. one around the bellhousing, one around the end. then you can use the ratchets to level the tranny one way or the other and it's easy to spin the tranny on the straps too.
Old Feb 12, 2007 | 11:54 AM
how long did it take you to get the tranny to hook up? also you were not doing it by yourself were you? you had atleast 1 other person helping you?
Old Feb 12, 2007 | 02:06 PM
hondafan's Avatar
yeah, i had 2 people helping and it took about 15-20 minutes to get it on.
Old Feb 12, 2007 | 06:29 PM
another question, the clip that hooks the TOB to the pressure plate kept poping off, i think we over streched it so it was poping off real easy, did anybody have issues with it?
Old Feb 12, 2007 | 07:00 PM
CBRD's Avatar
stole our technique huh
just admit it
cb
Old Feb 12, 2007 | 07:52 PM
o.e.boost's Avatar
i know i accendently knock the wedge collar off when pulling out the trans and then during start up the car was making a ticking noise...or a really bad release bearing noise...i havent been able to do anything yet but i think i know the problem!!!...i think
Old Feb 12, 2007 | 09:23 PM
hondafan's Avatar
just admit it
cb
damn right! that's what you get for helping me! seriously, without CBRD, i don't know how i would've gotten the trans on! the 6-speed is gianormous and a bit harder to maneuver in than the 5-speed.
Old Feb 12, 2007 | 09:27 PM
what do you guys do to prevent knocking the round clip off the pressure plate?
