Bleeding the ACD
Old Feb 15, 2007 | 07:18 AM
Turbo Kyle's Avatar
Originally Posted by rraulston
PITA???? Not at all. Just use a little common sence and a highly qualified mechanic and he should figure it out in less than 5 minutes. Doing it this way adds 15 minutes to the entire job!!! Look, here is how i do it. I take out the 5 TC bolts that are easy. Then the one behind the banjo, i loosen it and walk the tc out as i keep loosning it. walk...loosen....walk....loosen then it comes out....line and all. When re-attaching the TC to the tranny....walk tighten....walk tighten....walk tighten and insert the other 5 bolts and tighten all 6 evenly. Ive done about 20 clutches and find the 6speeds no different than 5 speeds. They are all easy, just time consuming to do right. Tiltons suck.......but thats for another thread..... ray
Yoda Speakes! LOL
Old Apr 11, 2007 | 11:08 AM
awdboosted's Avatar
We use an extra cap with a fitting to bleed the diff. We pump compressed air with a blow gun into the top canister and open the nipple at the bottom until the fluid comes out clean. We are putting no more then 15-20 psi and it worked great for my set up.
Old Apr 12, 2007 | 06:17 AM
Aloosh's Avatar
Originally Posted by mac_05evo
Also, you can turn the key to the ON position and hold the gas pedal down for 3 or 5 sec (I forget exactly) while doing this. You will hear the pump come on but this way will require 2 people since one must be under the car opening and closing the valve.
does that trick work if you have 3 steady light and can some one take a pic of that valve
Old Apr 12, 2007 | 06:44 AM
Phalse's Avatar
Kind of a stupid question but I'm preparing to do my clutch in a few weeks and was worried about the ACD.
The method of walking the bolt out without breaking the line makes sense.. except for a question of why is there a banjo on the tcase for this? I thought the center diff was in the main tranny and the tcase had the front diff in it.. so where does the banjo go and how does it remain sealed if its pumping fluid into the main trans housing? Kinda confused and would love a bit more detail on this..
Old May 22, 2007 | 11:15 AM
FastAzzEvo's Avatar
The acd line is on the top of the transfer case. The transfer case and the ACD are the same unit. There is a seperation, but none u need to remove.
I removed the bolt just because it is easier to reach up there and get the bolt out that way.
We used the two person, hold the throttle down while the car was acc. Did it a few times until the fluid came out clear from the bleeder tap.
fireroasted
38
Sep 6, 2013 12:28 AM
CooleyKing
May 18, 2010 01:00 AM
Boost3dxEvO
Aug 22, 2009 06:58 PM
andrew_sup
Sep 28, 2007 01:53 AM
whiteevo311
Dec 20, 2005 07:43 AM
