650WHP on E85 and Meth!!! at 36lbs of Boost
Old Feb 14, 2007 | 09:23 PM
XK120's Avatar
wow props for doing something so cool!!!
Old Feb 15, 2007 | 06:29 AM
Paul Nelson's Avatar
I'm wondering if i would make more on c-16 and about 42lbs of boost
Old Feb 15, 2007 | 06:35 AM
alan678's Avatar
Nice numbers.....congrats!
Old Feb 15, 2007 | 06:46 AM
Slava's Avatar
awesome work guys. great car congratulations
Old Feb 15, 2007 | 06:51 AM
Ted B's Avatar
This may sound strange to some people, but something appears holding this car back - and it isn't the tune.
Look at the torque curve with respect to rpm. Would anyone care to take a guess at what's needed to get another 50-60hp out of it?
Old Feb 15, 2007 | 06:56 AM
Jasil's Avatar
Car seems to need some cams IMO. 650whp is very awesome, but I would like to see that T-4 breathe a little more.
Old Feb 15, 2007 | 06:58 AM
Ev0ikon's Avatar
Remember that E85 is heavily subsidized so the cost is very low right now. Hope that production will be so much cheaper that it will be competitive price-wise with Race Gas once the gov't stops paying farmers to make that stuff.
This powerband from 6-9K looks delicious! Congrats!
Old Feb 15, 2007 | 07:06 AM
FullBlown's Avatar
Awesome!! I cant wait till it gets warm here. What size lines did you use with the setup?
Old Feb 15, 2007 | 07:16 AM
Hmm im running the Brian Crower cams 280/280 cams. Ive also got +1 valves /springs...i didnt port the head only cleaned the bowls...
Old Feb 15, 2007 | 07:17 AM
Our clutch started slipping on the dyno so that could be some of it.
Old Feb 15, 2007 | 07:39 AM
Ted B's Avatar
Jasil is correct.
If one looks at the specs for those cams:
http://www.briancrower.com/makes/mit...g63_evo8.shtml
There are two things that immediately come to attention. The first is the fact that these cams only give 218/216 deg of duration at 0.050", which is not ideally suited for high rpm power. Likewise, I see "106" indicated, which probably refers to LC (for both). This would be akin to setting HKS cams at +2/+2, and would explain why the torque peak occurs at a relatively tepid 6k rpm and tapers sharply thereafter.
If you have cam gears, setting them to something like -4/-4 would be immediately helpful. If not, just know that porting the heads AND installing a different cam set will deliver at least a 10% increase in power (and that is a conservative estimate) as sure as death and taxes. If you want to know how to get 700+whp, that's the ticket.
And oh yeah, invest in a good clutch. You'll need it!
Old Feb 15, 2007 | 07:47 AM
Jasil is correct.
So cam gears instead of changeing the cams would help??
I could order Bushurs new set of cams ..TedB thanks for the insight this whole process is a learning experiance
Old Feb 15, 2007 | 07:48 AM
vmsturbo's Avatar
Holy crap, that must be a beast!
Old Feb 15, 2007 | 07:51 AM
Ted B's Avatar
IF that "106" refers to lobe centerlines, then cam gears should help immediately.
However, if you don't presently have cam gears, I would just consider saving my funds for a set of more appropriate cams AND a ported head.
Old Feb 15, 2007 | 07:57 AM
AngryJonnie's Avatar
whats awesome is my rpms at 9000rpm
Errrm, 9000?
E85 continues to amaze me in so many different ways. I just don't see any in the NE for sale?
