Help, RPM DIPPING.
Old Feb 16, 2007 | 12:29 PM
Kdash106's Avatar
Unhappy Help, RPM DIPPING.
i did search on this but didn't find anything, but after i took off my HKS BOV(i know.. it suck i shoudn't bought that thing) but i had it on for 1 day than took it off and i install my stock one on. after that when i boost and than go for a stop, my rpm would drop all the way to about 500 rpm than it bounce back up and stay idle at 900 rpm, it seems like it would only do it when i get off boost, but it does it sometime when i am not in boost. i went back and retighten everything that i loosen during the installation of the HKS. can anyone help me? thanks in adv.
Old Feb 16, 2007 | 12:37 PM
WaxThis2005's Avatar
I would think that your ECU has caliberated itself to compinsate for the HKS a little bit. If I were you disconnect your ECU and connect it after 15 minutes and let it figure out the stock derverter valve is back in,
Old Feb 16, 2007 | 12:42 PM
Kdash106's Avatar
disconnect ecu or the battery?
Old Feb 16, 2007 | 12:45 PM
smokedmustang's Avatar
Battery, disconnect for 10-20 minutes. Then reconnect, and start the car WITHOUT touching the gas. wallah.......Done!! Waxthis is correct.
Old Feb 16, 2007 | 12:47 PM
Kdash106's Avatar
okay, THANKS For the help guys, i'll go do it now. if it still do the same thing, i'll be back.!! lol
Old Feb 16, 2007 | 12:51 PM
Thank you, You live and learn, I know from experience!!!!!!! Everyone goes through this process!
Old Feb 16, 2007 | 12:52 PM
It might do it for alittle bit, give it a bit of time, and eventually it will get better and better intill you no longer notice it.
Old Feb 16, 2007 | 01:14 PM
Kdash106's Avatar
so i went out and just disconnect the red one, that should be fine right? or do i need to disconnect the black one too?
Old Feb 16, 2007 | 01:31 PM
fxyxixe's Avatar
Good luck starting the car... You just grounded all the power out of it.. IE it's draining right now. Go disconnect it.
Old Feb 16, 2007 | 02:15 PM
Kdash106's Avatar
well i did start my car already, i just disconnect the Red one, i left the black one on.
Old Feb 16, 2007 | 04:54 PM
You should have disconnected the BLACK one, NOT the red one. Thats what I do anyway, does it matter? Not sure.
Old Feb 16, 2007 | 05:01 PM
Kdash106's Avatar
really?? i thought the black one is just grounding, and red one is the one that run's thru everything in the car... can anyone tell me which one to disconnect?
Old Feb 16, 2007 | 05:46 PM
evo150's Avatar
disconnect the black one....leave it off for 10-15min...start the car and let it idle for 5min...done
Old Feb 16, 2007 | 05:57 PM
ill-luzion's Avatar
Its not that.^ its probably your Mass Air Sensor. Its probably not working right. I had it on my car for 3 weeks and then switched back to the stock one, but i still had the same problem as you. i just went to the dealership today and they said my MASS AIR SENSOR was faulty. Good thing its getting fixed under warrenty. Go to your dealership and have them check it out. hopefully your car is still stock. well good luck! let me know how it goes.
Old Feb 16, 2007 | 06:10 PM
Kdash106's Avatar
my car is stock cept for K&N drop in, but that should not void anything. i am gonna try what the others said, than if it still do that after a while i am gonna bring it in to the dealers.
