Help, RPM DIPPING.
Old Feb 17, 2007 | 01:43 AM
Kdash106's Avatar
Originally Posted by WaxThis2005
It might do it for alittle bit, give it a bit of time, and eventually it will get better and better intill you no longer notice it.
so how long will it take to get back to normal? we talking about week or days?
Old Feb 17, 2007 | 10:30 AM
Jim_Patterson's Avatar
Sure ya correctly installed the stock BOV? and hooked up the vacuum line correctly?
Old Feb 17, 2007 | 10:36 AM
EVOllie's Avatar
Originally Posted by ill-luzion
I would think that your ECU has caliberated itself to compinsate for the HKS a little bit. If I were you disconnect your ECU and connect it after 15 minutes and let it figure out the stock derverter valve is back in,
Its not that.^ its probably your Mass Air Sensor. Its probably not working right. I had it on my car for 3 weeks and then switched back to the stock one, but i still had the same problem as you. i just went to the dealership today and they said my MASS AIR SENSOR was faulty. Good thing its getting fixed under warrenty. Go to your dealership and have them check it out. hopefully your car is still stock. well good luck! let me know how it goes.
Dont mean to hi jack this thread...but what did the dealership do to your MAS? clean it or replace it?
Old Feb 17, 2007 | 12:46 PM
Kdash106's Avatar
i believe so, the Stock BOV top side should be facing the radiator right?
Old Feb 17, 2007 | 05:36 PM
ill-luzion's Avatar
They are going to replace it. FOR FREE! WOOHOO
Old Feb 17, 2007 | 05:58 PM
Kdash106's Avatar
did u just bring it in or u made a appointment? i am thinking about doing it too, but i don't want to leave my car there, cause lotz of people state that their cars has been driven after they picked it up.
Old Feb 17, 2007 | 10:07 PM
EVOllie's Avatar
what do you mean? like they take your car out for a joy ride? Well im sure they gotta test the car out after working on it i guess. Write down your milage if u have to drop it off.
Old Feb 17, 2007 | 10:15 PM
EVOllie's Avatar
I would make sure 100% that everything is tight, or do a boost leak check if possible. If re-setting ur ecu doesnt work.
My car was doing the same thing when i had a small boost leak at one of the boots.
Have you thrown any codes yet?
Old Feb 17, 2007 | 11:16 PM
Kdash106's Avatar
i haven't throw any code yet, but i am gonna have a friend check it out, i have retighten everything twice. but i don't know maybe it could be the bottom IC pipe?,
and there is some people on the forum say that the service people will drive their car for joy ride, and when they get it back, it has like more than 5-6 miles on it, test drive don't need that much miles. there is few thread out there like this.
Old Feb 18, 2007 | 12:22 AM
Kdash106's Avatar
bump...
Old Feb 18, 2007 | 08:22 AM
ill-luzion's Avatar
of course they are going to test it out, just take it to the dealer and tell them whats going on, they tell you whats wrong with it, unless they're trying to screw you. Good thing my dealership isn't like that.
Old Feb 18, 2007 | 09:39 AM
EVOllie's Avatar
thats is where the majority of my leaks are...the intercooler pipe (at the end tanks) but i have a aftermarket intercooler, old coouplers and sh@tty hose clamps. I just ordered some nice new boots from full-race, and t-bolt clamps.
to fix that problem.
TURBODAWG
49
Apr 11, 2015 02:55 PM
chendu1280
Nov 12, 2010 11:55 PM
NiteWalker7.5
Jul 27, 2010 09:16 AM
guitardave24
38
Jul 26, 2010 03:22 PM
ArchieBabes
Feb 23, 2006 08:42 AM
