Injectors
Old Feb 18, 2007 | 10:42 AM
ihatepotholes's Avatar
Injectors
whats the biggest injectors factory evo ix' ecu can control? i have reflash right now adn im jumping on the bandwagon like alot of people, getting an Evo green soon. i heard 680cc is ideal for that turbo, or should i go a lil bigger?
Old Feb 18, 2007 | 10:47 AM
Evil_1's Avatar
680's would be minimum if you're running meth or alky. I'd step it up to at least 770's or 880's if you're not running meth. You can scale the injectors in ECU flash for either or. I have 680's with meth and will step up to 880's soon currently on 20GLT.
Old Feb 18, 2007 | 10:48 AM
dubbleugly01's Avatar
The factory ECU will handle injectors up to 880-1000cc. It gets a little dicey, but you can get them to idle with EcuFlash.
Old Feb 18, 2007 | 10:49 AM
sorry im not too bright lol, what did you mean by that? i thought i heard stock ecu can only use 680
Old Feb 18, 2007 | 10:51 AM
scottatyamaha's Avatar
I was told to run 680cc injectors on stock ECU and the 20glt
Old Feb 18, 2007 | 10:54 AM
Evil_1's Avatar
go to Evo Engine Management / Tuning Forums/ECUFlash. It's all explained in there on how to rescale your injectors when going up to larger injectors.
Old Feb 18, 2007 | 10:56 AM
TeStUdO's Avatar
You can get away with the 680's. If you want to really push the turbo you will need to go bigger though.
Old Feb 18, 2007 | 11:10 AM
really? when i called up buschur they said you can get away with stock injectors.
Old Feb 18, 2007 | 11:20 AM
TeStUdO's Avatar
Stock injectors are 560cc. Evil_1 is right, 680cc's is a good choice as a minimum.
Old Feb 18, 2007 | 11:22 AM
i don't plan to run alky/meth if i get this turbo, so it's either alky or fp green. 680cc is enough? just pump gas tho
Old Feb 18, 2007 | 11:26 AM
TeStUdO's Avatar
Yeah 680's will be fine. At least do a race gas tune so you can get a good amount of power out of the turbo.
Old Feb 18, 2007 | 11:27 AM
Planet Evo's Avatar
The stock ecu can take well over 1000cc injectors if they are of the same design and resistance as the stock units. Plan ahead and go with 880's.
To give a slight example, 780cc injectors at 82% duty (for an evo with a 50 trim) is good for about 525
Old Feb 18, 2007 | 11:35 AM
Evil_1's Avatar
If you're going to go with 680's, why not just get the 780's since it's the same price as the 680's. That way, if you should want to run 28+psi, there's more than enough there to support the high boost. Trust me, if you're going with the 20GLT, you're going to want to run 28+ and you'll get lots of
Old Feb 18, 2007 | 11:58 AM
tru do you know who makes 780s thats same design and resistence as the stockies?
Old Feb 18, 2007 | 12:28 PM
Ted B's Avatar
Bigger than you'll need
680s would be fine for you. Even if you used methanol injection, 680s are fine for you, because methanol reduces the load on injectors, not raises it. Even if you used race fuel, I'd be tempted to say that 680s are probably still fine for you. Be sure you upgrade your fuel pump if you haven't already.
