Injectors
Old Feb 19, 2007 | 03:41 PM
ihatepotholes's Avatar
Originally Posted by Ted B
Bigger than you'll need
680s would be fine for you. Even if you used methanol injection, 680s are fine for you, because methanol reduces the load on injectors, not raises it. Even if you used race fuel, I'd be tempted to say that 680s are probably still fine for you. Be sure you upgrade your fuel pump if you haven't already.
im only gonna run on pump gas, if i do get the turbo. yes i have walbro 255. another question for you... how is HKS DLI II? notice any difference?
Old Feb 19, 2007 | 05:11 PM
EvoTech's Avatar
Originally Posted by Planet Evo
The stock ecu can take well over 1000cc injectors if they are of the same design and resistance as the stock units. Plan ahead and go with 880's.
To give a slight example, 780cc injectors at 82% duty (for an evo with a 50 trim) is good for about 525
What do you base that on? The injector drivers from the stock ECU could loose control over a 1000 cc injector. It would make for a dangerous tune and "loosing control" over injectors could quickly result in a blown engine.
Old Feb 20, 2007 | 04:56 AM
Ted B's Avatar
All the injector sizes discussed here are low-Z peak and hold types, and all have the same resistance.
There is no reason why the stock ECU cannot effectively control a 1000cc injector, however, there is no reason to use an injector that large unless one is using a turbo larger than a GT35R, which isn't best suited for the stock ECU/MAF setup anyway.
The HKS DLI II seems to improve the efficiency of the stock ignition and reduce the incidence of misfire. I'd still recommend gapping the plugs to 0.022".
Old Feb 20, 2007 | 09:30 AM
SWOLN's Avatar
Ted would this be the same if one were to use Buschurs' hi flow pumps? Although, I realize it's not necessary, will it effect the control of the injectors, ect...
Old Feb 20, 2007 | 09:37 AM
Planet Evo's Avatar
If the proper battery compensation is applied, and the computer is calibrated internally to handle the flow characteristics of the larger injectors, then HOW would it "loose control"?
Im not sure what you mean with those words "loose". Please explain.
As Ted has explained there really isn't a need for anything that large unless your running avery large turbo, and loss of efficiency causing brake specific fuel consumption rates well over stock like levels.
Hense the reason I mention go with 880cc for future use. Precision Turbo sells a stable set for a good price.
Old Feb 20, 2007 | 10:59 AM
Ted B's Avatar
Using said pump should not make for any difference in the injector size. We're not dealing with enough power here to tax a regular 255 lph pump.
However, I might mention that for big turbo setups, one may not realize it if the pump cannot maintain the desired line pressure, in which case he would find himself needing unusually large injectors to keep things together.
Old Apr 30, 2007 | 03:03 PM
mplspilot's Avatar
it's been a while, but...
Would 1000 injectors be good on a stock ecu for e85? with one walbro?
napsu67
Oct 20, 2015 09:45 PM
mrevolution9
Aug 3, 2009 09:18 AM
drewdq
Jan 8, 2009 11:23 PM
Slow Evo
Apr 26, 2007 04:37 PM
DS-03evo
12
Feb 19, 2007 01:39 PM
