Turbo Spool Fluttering
Old Feb 18, 2007 | 02:49 PM
LockportEvo8's Avatar
Unhappy Turbo Spool Fluttering
Have an issue...
Under WOT I Have an issue, the turbo spooling isn't constant... sounds like a fluttering under full boost... I dont notice any boost fluctuations, just the sound seems to flutter and is starting to disturb me... Any help would be great.
Oh, it's an 05 evo 8 GSR.
Mods are: AMS Stage 1 (Ditched the AFC, gonna get it reflashed.) 3" DP, 3" TP, Megan Racing Manifold, AMS MBC.. Those are the only pertinent mods...Please Help!
Old Feb 18, 2007 | 03:02 PM
joeMama's Avatar
do you have a BOV, it may not be installed correctly, check that.
Old Feb 18, 2007 | 03:42 PM
vwjeff's Avatar
You just have compressure surge, you'll be fine. Its the cold air causing it.
You should hear my car
Old Feb 18, 2007 | 03:44 PM
TURBevO8's Avatar
Compressor surge is bad and will wear out your turbo much faster than under normal circumstances. Do you have a MBC? How is it hooked up? You say there is not fluctuation in the boost at all? So your needle on your boost guage holds solid?
Old Feb 18, 2007 | 03:46 PM
prostcj's Avatar
Turn down your boost a little. What you're describing is definitely surge.
Old Feb 18, 2007 | 04:02 PM
vwjeff's Avatar
Who cares its a stock turbo
Gives him a reason to get a BR 35r kit
Old Feb 18, 2007 | 04:06 PM
evoboy8990's Avatar
ya im getin this turbo sputtering sound also. i got a 20g tho ... mines worse trust me, i live in illinois n it is freezing here right now. car drives like ****.
Old Feb 18, 2007 | 04:07 PM
STOCK_EVOLUTION's Avatar
Could it be maybe your misfiring????
Old Feb 18, 2007 | 04:15 PM
prostcj's Avatar
It's a description of surge.
Old Feb 18, 2007 | 04:22 PM
tony_b's Avatar
Compressor surge doesn't happen under WOT. Compressor surge happens when you let off the throttle and the pressure backs up.
Old Feb 18, 2007 | 04:28 PM
BoostWhore's Avatar
My 50 trim does it w/ my new forge rs valve i need to try and adjust it im pretty sure its the cause b/ it never use to do it w/ my aps
Old Feb 18, 2007 | 04:50 PM
Danny23's Avatar
Turbo comp. surge and bov fluttering are completely different things. Most people think they are the same when discussing there problems with it.
Old Feb 18, 2007 | 04:58 PM
prostcj's Avatar
It happens under wot with low rpm typically. What you're describing sounds like a BOV that doesn't lift.
Old Feb 18, 2007 | 05:10 PM
lotsOboost's Avatar
I noticed that on my car a while back but never thought anything of it, you notice it more on the highway with the windows down and you floor it, its too hard to notice with the windows up. I have checked all my connections and everything was tight, so i interested to know whats the problem too. Oh my car had the hks ssq on it when I bought it and its recirc'd, I never had any stalling or surging problems yet, so what can the problem be??
Old Feb 18, 2007 | 05:43 PM
joeMama's Avatar
try getting a MR Bov and throw it in, see what happens. I dont think its comp. surge. I had a similiar prob. and it turned out to be a BOV defect........ just my .02
