not boosting right...
Old Feb 18, 2007 | 08:29 PM
EVOIXMR8916's Avatar
nope both are tight and snug...
Old Feb 18, 2007 | 08:40 PM
scottatyamaha's Avatar
well ya got me....I am stumped then.
Old Feb 18, 2007 | 08:44 PM
dealer should fix it right....
Old Feb 18, 2007 | 08:53 PM
bump...anyone else....
Old Feb 18, 2007 | 09:00 PM
evo150's Avatar
have you checked your licp, and the uicp at the throttle body?
Old Feb 18, 2007 | 09:05 PM
ok goin now..lol
Old Feb 18, 2007 | 09:12 PM
evrblazin's Avatar
just take it to the dealer while u are still stock ,which will be like another week
Old Feb 18, 2007 | 09:14 PM
shhhh.....lol i know damn exhaust is on back order.....lol
Old Feb 18, 2007 | 09:16 PM
fraser91084's Avatar
be sure to check the connections around the bov. mine was alittle bit loose and it made my car drive like crap
Old Feb 18, 2007 | 09:17 PM
i felt it on bolt i cant get to and the othe rone was loose...
Old Feb 18, 2007 | 09:26 PM
bandwagon's Avatar
the dealer will give you **** try to void your warranty and figure some other way to screw you over but if all your hoses are on bov and ic pipes and sleeves are on then one can never tell. good luck
Old Feb 18, 2007 | 09:28 PM
nope not the fix....licp is ok
Old Feb 19, 2007 | 09:20 AM
bump
Old Feb 19, 2007 | 11:56 AM
Danny23's Avatar
Only way your going to find your leak is to do a boost leak test. Bring it in.
Old Feb 19, 2007 | 12:58 PM
Jersey Dino's Avatar
if you are getting a really loud hissing noise it should be leaking on the intake side. the only time I have ever had a hissing noise was when the inlet pipe on th eturbo wasnt tightend down enough. it would whine like a supercharger and make no boost. sounds like it wants too but its just sucking in air and not boosting. when the intercooler hose pops off the throttle body, it just goes nowhere. and almost stalls. if you are a hands on guy, get under the car and take the plastic undertray off and inspect all your boost tubes.you can get a good look at just about everything from here. good luck
