not boosting right...
Old Feb 18, 2007 | 07:06 PM
EVOIXMR8916's Avatar
so this morning i was driving on my way to work and noticed my car was acting weird.....no power at like 2.5-3.5 k so i gave it a few 2nd and low 3rd gear pulls and 1 7k 3rd gear pull... i noticed that i wasnt boosting at all...i was peaking at .6 bar and tapering down to .4 at 7 k with a loud hissing noise....any ideas....
Old Feb 18, 2007 | 07:08 PM
izabran's Avatar
one of your hoses might have popped off... same thing is happening to me... but mine is spiking early tehn spikes again... 2 it goes twice in one gear
Old Feb 18, 2007 | 07:09 PM
RoadSpike's Avatar
Doesn't that scream boost leak to you?
Maybe a IC hose came partially off or is loose. Pressurize your system to do a boost leak check and find out if you have an issue
i was hoping not so....damn ill check it out now....
Old Feb 18, 2007 | 07:10 PM
thanks time to get the jack out....lol ill be back in 20 mins with the news... ill re tighten everything while in at it...
Old Feb 18, 2007 | 07:11 PM
RoadSpike's Avatar
Boost solenoid issue prehaps? Could maybe be sticking and cause interesting spiking.
Do you use a MBC? EBC?
Old Feb 18, 2007 | 07:29 PM
nope completely stock except for exterior mods for now...what hose usually is the problem stock because i have read that its a certain one but don't remember...
Old Feb 18, 2007 | 07:33 PM
RoadSpike's Avatar
It runs from the waste gate over to the boost control solenoid underneath the stock air filter. Should be T'ed off of the intake with the pill on the solenoid side if i can remember correctly.
If the pill is gone usually you don't get more than around 14 psi of boost.
Old Feb 18, 2007 | 07:35 PM
i usaully hit 19 psi and taper down to 17-18
Old Feb 18, 2007 | 07:57 PM
lol my notebook is sitting on my engine right now ...lol
Old Feb 18, 2007 | 08:01 PM
damn i tightened most of the stuff went for a quick ride and i smell exauhst being put through the air vents at 5k and above...and my ac is off....weird..
Old Feb 18, 2007 | 08:07 PM
bump....
Old Feb 18, 2007 | 08:13 PM
scottatyamaha's Avatar
Check your intake snorkle and make sure both clips are holding in down.
Old Feb 18, 2007 | 08:17 PM
snorkel???
Old Feb 18, 2007 | 08:20 PM
The peice that comes out of the top of the airbox and pulls in air from outside. It has two snaps that hold it down and keep it from flopping around. If one of those snaps comes loose it can get sucked up against the hood of the car causing simptons that you are describing.
