Weird boost problem....Help
Old Feb 19, 2007 | 03:58 PM
akunochi's Avatar
Ok here are the symptoms.
5500+ RPMS
Any boost higher that 1.37 bars.
Feels like fuel cut (IE engine skipping a beat), but data logging shows no signs of timing pull.
Here are my mods:
HKS TBE, Megan racing test pipe, Megan racing down Pipe, Apexi AVC-R, Walboro fuel pump, K&N air intake. I can replicate the problem on demand. Any ideas?
Thanks Seth
Old Feb 19, 2007 | 05:23 PM
RoadSpike's Avatar
Take out your plugs and regap or replace them.
I had the same issue when i went to a mere 20psi with a Jestr tune. New plugs, problem solved
Hope that helps.
Old Feb 19, 2007 | 05:59 PM
akunochi's Avatar
Ok will try that. I'll order new plugs tommorow. What gap did you go with?
Old Feb 19, 2007 | 06:02 PM
bluebyu36's Avatar
26-28
Old Feb 19, 2007 | 06:05 PM
ak47po's Avatar
Old Feb 20, 2007 | 08:24 AM
akunochi's Avatar
bump for any other ideas just incase.
Old Apr 8, 2007 | 06:09 PM
ItalyIX's Avatar
I am getting this too. I am flashed and still on stock exhaust. When I hit 5500rpm, the car looses power hard. Feels like there is no more boost.
Silver06evo9mr's Avatar
boost leaks?
Old Apr 8, 2007 | 06:42 PM
Warrtalon's Avatar
Akunochi, if you're not tuned, then it's fuel cut. This is not a plug problem. Fuel cut won't show up on logs. Btw, you have an HKS cat-back, not an HKS TBE.
ItalyIX, if you have the stock intake still, then for you it's the intake snorkel missing its clips.
Old Apr 8, 2007 | 10:39 PM
ItalyIX's Avatar
Warrtalon, you weren't in my garage last night, were you? My intake snorkel IS missing both clips that hold it in front. How did you know?
So, by putting them back it should solve the problem? I was installing all the engine bushings last night and forgot to put the clips back in.
Old Apr 9, 2007 | 12:08 AM
RoadSpike's Avatar
Probably has read posts like this.
https://www.evolutionm.net/forums/sh...clips+blocking
evoviiihan
10
Oct 22, 2016 10:00 PM
EvoLucio
Mar 9, 2016 09:42 PM
EvOstyleZ
Oct 27, 2010 03:14 PM
house#21
Jun 14, 2009 10:37 PM
Warrtalon
42
Jan 15, 2006 07:46 PM
