ARC Induction Box Pre/Post dyno...
you will definitely see noticeble gains on the hks intake kit. I have gained 8whp with it, and it was used as as an open element setup w/o the Carbon Fiber HKS Kansai Box. And I think with the kansai box, the air temp should lower and gain a bit more. I will have some dyno numbers soon.
no, i am saying HKS RS intake kit gained about 8whp alone. And w/ HKS Kansai CF box, im expecting it to gain a bit more on top of the RS reloaded kit itself since the CF box will lower the air temp, and A/F ratio should be more stable.
Ok some data:
With stock airbox with drop-in filter:
Air Temp (measured at MAF):
76.84@3500rpm
77.62@5000rpm
78.41@6000rpm
78.41@7000rpm
Airflow:
899.47@3000rpm
1025.27@3500rpm
1182.52@4000rpm
1463.57@5000rpm
1603.95@5500rpm (maxed out in evoscan)
With ARC airbox:
76.06@3500rpm
74.52@5000rpm
73.76@6000rpm
73.00@7000rpm
Airflow:
792.54@3000rpm
1044.14@3500rpm
1207.68@4000rpm
1402.67@5000rpm
1528.47@5500rpm
1603.95@6000rpm (maxed out in evoscan)
76.84@3500rpm
77.62@5000rpm
78.41@6000rpm
78.41@7000rpm
Airflow:
899.47@3000rpm
1025.27@3500rpm
1182.52@4000rpm
1463.57@5000rpm
With ARC airbox:
76.06@3500rpm
74.52@5000rpm
73.76@6000rpm
73.00@7000rpm
Airflow:
792.54@3000rpm
1044.14@3500rpm
1207.68@4000rpm
1402.67@5000rpm
1528.47@5500rpm
Ok some data:
76.84@3500rpm
77.62@5000rpm
78.41@6000rpm
78.41@7000rpm
Airflow:
899.47@3000rpm
1025.27@3500rpm
1182.52@4000rpm
1463.57@5000rpm
With ARC airbox:
76.06@3500rpm
74.52@5000rpm
73.76@6000rpm
73.00@7000rpm
Airflow:
792.54@3000rpm
1044.14@3500rpm
1207.68@4000rpm
1402.67@5000rpm
1528.47@5500rpm
76.84@3500rpm
77.62@5000rpm
78.41@6000rpm
78.41@7000rpm
Airflow:
899.47@3000rpm
1025.27@3500rpm
1182.52@4000rpm
1463.57@5000rpm
With ARC airbox:
76.06@3500rpm
74.52@5000rpm
73.76@6000rpm
73.00@7000rpm
Airflow:
792.54@3000rpm
1044.14@3500rpm
1207.68@4000rpm
1402.67@5000rpm
1528.47@5500rpm
Thanks for posting this data but it really doesn't show too much of a gain. All it does show is that the MAF readings are a lil more erratic as opposed to uniform like the OEM intake box. Specifically look at 3000 RPM's for the ARC box Vs. OEM, it is way lower strangely but I may attest that too WHEN you hit the throttle so then look at 5000 Rpm's; it is lower for the ARC box and then box max air flow rates are the same as the OEM air box. I will say that I am surprised that the intake temps are lower and it just proves my theory that the air is getting into that engine compartment and not heating up as much as we think it is. But then again, we have no idea if the TEMP changed bewteen runs r when the runs were recorded.
Please do a test on the HKS unit, with the hard piping and without if possible.
yeah i noticed the airflow numbers also. It is important to note that the temperatures went down as rpms went up using the arc intake rather then go up when using the stock intake.
Face it all the stock components, regardless of the vehicle, will be less effective due to cost restraints then after market parts. That's why aftermarket tuning is an over $1B industry. laters pk
I find this very interesting and I must say that I am some what skepitcal about the data on the oem box vs. the ARC box. You could have made more HP just by the outside climate being different than the first time you dyno'd the car. I also question the temperature of the ARC box vs. the OEM. Aluminum will conduct more heat when compared to the plastic of the stock airbox. Either way it looks like there is a nice gain there. I just wonder how it will perform on the road and in traffic conditions.
It might be expensive but look at the cooling difference ( : it seems like the one to get! I would rather pay money for gains than spend less on worse quality! Good thread bro!
