Exhuast testing Round 2 - HKS vs Buschur
Old Feb 20, 2007 | 09:43 AM
  #46
trjx24's Avatar
ive seen a lot of great things from buschur and in every thread 4 wheel slide is in there bashing buschur making some comment about the test.. hater in the house..
Old Feb 20, 2007 | 10:02 AM
  #47
Ev0ikon's Avatar
Thanks Al for this test.
Is the testing HKS system still have the 2.5" neck at the cat?
One more thing I would like to see from this test is an audio clip comparing the 2 systems. I have done that myself and WHOA! What a difference!
Old Feb 20, 2007 | 10:37 AM
  #48
anjapower's Avatar
So if the HKS exhaust used a 3" diameter downpipe and a regular non-resonated test pipe, it would make as much power as the other exhaust.
Sounds like people should continue to buy the Megan and save ~300 bucks.
  #49
SubiEvolved's Avatar
Al i would like to see how a TXS exhaust compares to the buschur. Ive always made good numbers with both my evos running the TXS. When i get the car fixed maybe ill take a trip down and we can do a test on a competely built evo...
Im sure the buschur is lighter but I would like to see if it makes a bigger difference in HP on a fully built evo..
Old Feb 20, 2007 | 10:49 AM
  #50
BURNALL_4's Avatar
that wasn't a very good judge of weight.....both exhaust systems were dirty, and the HKS can is bigger so it will have more dirt on it. i bet thats where the extra 20lbs came from......clean and retest.
Old Feb 20, 2007 | 11:12 AM
  #51
joedr's Avatar
EvoM Moderator
Well....
I am pleased to hear that Al and to see that this was a good comparison between two TBEs.
I do not doubt that BR would make more power than the HKS. BTW, I have a BR TBE and my buddy has the HKS with same mods. I always run in front of him in 2nd and 3rd pulls. Maybe is the driver! ;-)
Very impressed how close the HKS was to the BR! Good informative thread!
Old Feb 20, 2007 | 11:17 AM
  #52
DynoFlash's Avatar
Originally Posted by mchuang
That is exactly what I was going to ask. Seems baseline was done with the HKS, and then put the Buschur on and tuned it for about 8 runs, but oh well. I would actually like to see run 14 or 15.
What I did for a fair comparision was to tailor the a/f curves to be idential between the two units
When the Buschur unit was first put in it was a bit leaner on the top end
I dialed in the a/f tables 100% the same and the same timing to try and make as close a comparision as possible
You can see the a/f curves and they are nearly 100% identical
I think the reason why I did this was becuase the power was so close between the two the gain / or loss could have been explained by tuning alone - which is why I wanted the tuning to be identical
The near 9 whp gain in power in the Buschur unit up top required a increase in fuel
I hope that explains why we did a lot of pulls on this car
AL
Old Feb 20, 2007 | 11:19 AM
  #53
DynoFlash's Avatar
This system had no neck at the cat I could observe
Old Feb 20, 2007 | 11:25 AM
  #54
4WS Tuning's Avatar
if the hks had a normal test pipe, the results would be the same.
this just proves that a 3" pipe is a 3" pipe.
Old Feb 20, 2007 | 11:33 AM
  #55
streetturbo's Avatar
Originally Posted by Pure Playaer
its already been done, minus the test pipes
Buschur tbe had test pipe and ebay tbe had high flow cat if i remember correctly. So it's not been done yet. CBRD waiting for the results
Old Feb 20, 2007 | 11:36 AM
  #56
Pure Playaer's Avatar
exactly, htats why i said its been done, minus the testpipe lol..
re read my post
btw for everyone, warrtalon did a megan vs buschur exhaust write up..
just search warrtalons old thread posts
Old Feb 20, 2007 | 11:42 AM
  #57
ultimatesteve's Avatar
Very interesting, and I just happen to know someone with a hks system for sale
But what I would really like to see is a comparison with the Greddy TI
Old Feb 20, 2007 | 11:48 AM
  #58
value's Avatar
Hey Al regardless of all the heat you take thanks for taking the time testing
Old Feb 20, 2007 | 12:13 PM
  #59
AWDTurbo4's Avatar
Originally Posted by CBRD
we are going to do some before and after testing shortly with an ebay exhaust... and two other combinations... one catless, one resonated and catted...
ill have before and after dyno plots with afr, boost, and powa!
cb
hope u test the right one please
Old Feb 20, 2007 | 12:29 PM
  #60
TURBevO8's Avatar
It should be noted that the taper at the cat is soooo slight. I think most people who ***** about this dont even own this exhaust or have ever looked at one in person. Also, look now straight the HKS is. Very similar to the Buschur and actually eliminates one bend compared to the Buschur. I think that is why it makes good power. Some other brands have bends that do make a difference. The HKS does not.
