help!!! greedy type s causing surging idle
Old Feb 20, 2007 | 10:18 PM
riceball777's Avatar
with the forge rs the car runs great and perfect
but with the greedy type s (recirculated) with the single spring mod the car runs like total crap. the idle surges like crazy. like there is a vacuum leak
and it almost stalls when you come to a stop.
whats wrong with my type s
Old Feb 20, 2007 | 10:43 PM
tony_b's Avatar
You either have it set too soft or it's not hooked up correctly. Do you have the bottom nipple hooked to a boost source or blocked?
Old Feb 20, 2007 | 11:14 PM
i have the single spring mod done and i have the bottom nipple open with nothing attached
should i put both springs in and connect the lower nipple to the intercooler piping ??
Old Feb 21, 2007 | 02:19 AM
anyone else?
Old Feb 21, 2007 | 11:00 AM
tony_b's Avatar
For now, try just blocking it off. If it still surges, hook it up to a boost source to make it open faster.
Just put a small piece of hose over the bottom nipple and put a screw in the end to seal it. Should be fine.
Old Feb 21, 2007 | 12:22 PM
deadbeatrec's Avatar
heres a tip for u......
HOOK THE FORGE BACK UP!!!!
evo9mrgurl
18
May 26, 2014 09:33 AM
PINK LANCER
Lancer Engine Tech
Nov 9, 2013 08:11 PM
dsmmk4
Mar 17, 2012 11:02 AM
enragedpanda
Sep 13, 2011 07:01 PM
carlosdevil10
Lancer Aftermarket Forced Induction Tech
May 17, 2009 06:20 PM
