Boost creep... how bad is it?
Old Feb 24, 2007 | 11:18 PM
Eggy's Avatar
Well I noticed that after I got my cat back exhaust I have been able to hit around 1.5 bar instead of the usual 1.4. My friend says this is because of boost creep and that it's not really good for the engine, and it means my car is running a bit lean.
I know there are a ton of people running unflashed evos with cat-backs. Does everyone else experience this as well? Is it really bad for the car? I thought if I got a cat back I wouldn't have to flash just yet >.<
What's going on!?
Old Feb 24, 2007 | 11:37 PM
chaotichoax's Avatar
boost creep is definitely not good...but hitting 1.5 over 1.4 isn't really bad creep if creep at all
you added a more freeflowing exhaust which in turn made it easier for your turbo to breathe thus increasing the boost output
creep is only an issue when it climbs from say 1.4 to 1.8 and your wastegate is fully open and you can't control it...a boost controller should help with this
usually boost creep leads to fuel cut as the engine uses this as a preventative measure to prevent future damage
I'm pretty sure that it doesn't make your car run any leaner in your condition though...the ecu continues to add fuel so you should be okay
if any of my information is inaccurate please let me know and I will edit it
Old Feb 25, 2007 | 12:04 AM
Eggy's Avatar
That's good to hear. I was happy to hit 1.5
Old Feb 25, 2007 | 12:12 AM
RunEvo's Avatar
that's not a boost creep since your boost is staying at 1.5 bar.
Old Feb 25, 2007 | 12:16 AM
yeah, creep continues to climb...you are just experience the effects of moe flow but it is perfectly safe
but a mbc/ebc would be a good mod to control peak boost/creep all together
Old Feb 25, 2007 | 12:19 AM
Eggy's Avatar
If I notice it keep going up I will look into an MBC.
No one else experiencing this????
Old Feb 25, 2007 | 12:22 AM
it's also more common when it is cold out...because the air is denser
usually in the cold I experience boost spike...so I turn back my mbc a little to compensate for the denser air
Old Feb 25, 2007 | 12:32 AM
RunEvo's Avatar
almost everyone does...
Old Feb 25, 2007 | 01:24 AM
fusionchicken's Avatar
+1.
i noticed the same thing after getting my TBE, so i got a boost controller instantly to control the peak...i peaked as high as 23psi after installing the TBE...
