Leaking from BOTH axles after clutch install ??
Old Feb 26, 2007 | 10:27 AM
grenade's Avatar
Well, I got everything bolted back up, and when filling the transmission, it started to leak at the bottom of the seal on the axle going into the tranmission. Everythings bolted up, and torqued down, and looks good, but its now leaking from BOTH sides.
Only thing I can think of is that the axles are not seated or pushed far enough in. There's about 1/2 of the output shaft showing on both sides.
Anyone got any tips? TIA
Old Feb 26, 2007 | 11:24 AM
tbutterfield's Avatar
there is a seal on each side that if you tore when installing it would leak.
If you didnt have them in all the way you most likely couldnt of finished the install.
Check the seals.
Old Feb 26, 2007 | 11:30 AM
Tim@AMSperformance's Avatar
make sure the axles are all of the way in the trans
Old Feb 26, 2007 | 11:35 AM
joeMama's Avatar
If those seals are torn its gonna be a messey scene. Im not sure how easy they are to get a hold of, new ones anyway.
Old Feb 26, 2007 | 11:52 AM
grenade's Avatar
Check the seals.
This is what I was thinking. I can get one of the two seals here in town. I really dont think that they are torn. Were going to check tonite. Thanks
Old Feb 26, 2007 | 01:24 PM
grenade's Avatar
Anyone else got some tips?
Old Feb 26, 2007 | 01:42 PM
KevinD's Avatar
sounds like you didn't push them in far enough.
there is a c-clip that needs to get shoved far enough in until it locks the axle in place. you need to basically ram the axle in until you hear it click. you'll know its in when the metal seal cover is just about flush with the tranny. there will be a small amount of play, but you will not be able to pull the axle out by hand.
Old Feb 26, 2007 | 01:44 PM
Curt@MrLed's Avatar
Former Vendor
you should only see about 1/4 inch of the spline sticking out from the gasket..
if there bad no biggie to change..
Old Feb 26, 2007 | 01:59 PM
grenade's Avatar
Yeah. I do understand this, but I guess its not far enough in. There's about 1/2 inch sticking out. Ill re-try to set the axles tonight. Thanks for the info.
Old Feb 26, 2007 | 02:00 PM
grenade's Avatar
Thanks for the info. Ill look into it tonite.
MitsuJoe
468
Feb 20, 2016 11:17 AM
JTCB
Apr 8, 2015 02:46 PM
AcePitcher11
17
Feb 4, 2012 10:54 AM
88crxvtec
Apr 24, 2009 05:15 AM
AfireINSIDE
Jun 22, 2007 07:30 AM
