Which Spark Plugs should i use?
Old Feb 27, 2007 | 08:17 AM
jusa4cyl's Avatar
I have been doing a search on this and found thet the NGK BR7ES is what most recommend. However when I look up my plugs at NGK they say use the BPR7ES and the BPR7EIX which is the iridium and is a better plug. I'm guessing the BR7ES isnt iridium? Which ones do you recommend?
Old Feb 27, 2007 | 08:34 AM
Dapper Dan's Avatar
use the ngks........
Old Feb 27, 2007 | 08:49 AM
jusa4cyl's Avatar
They are both ngk plugs.
Old Feb 27, 2007 | 08:56 AM
Murf's Avatar
go with the BPR7s
Old Feb 27, 2007 | 08:59 AM
tweakdsm's Avatar
Iam using NGK BPR7ES.
Old Feb 27, 2007 | 01:48 PM
jusa4cyl's Avatar
bump
i need some more opinions
Old Feb 27, 2007 | 01:55 PM
Warrtalon's Avatar
If you need more opinions, then why not read the hundreds of threads that discussed this in the past? The S plugs are copper, and the IX plugs are Iridium. Iridiums last longer, but they cost a lot more. Most of us just use the coppers and change them out every 5k miles or so. The coppers can withstand high boost quite well, but they just don't last long. They also are very cheap at under $2/plug. I usually buy 20 at a time (2 boxes).
NGK BPR7ES is the standard for stock or lightly modded Evos, but you may need heat range 8 (BPR8ES or BR8ES) with all those mods...
Old Feb 27, 2007 | 02:03 PM
jusa4cyl's Avatar
I said i did a search here and i did do some research elswhere. I just wanted some experience evo owners opinions versus a non evo owner. Your reply is the reason i'm asking the question. you say the 8 and everyone else says the 7's. Thank you for the input War.
Old Feb 27, 2007 | 02:05 PM
Warrtalon's Avatar
No, not everyone else says the 7s. We say 7s for the MOST PART, but you _may_ need 8s. YOu won't know until you use them. Typically, for every 100whp over stock, you go up one heat range - that is the standard, but some do it earlier or later. It all depends on how your car behaves. Now that I run 26psi daily on alky, I always use 8s. Before alky, I always used 7s.
I know you want opinions from Evo owners and the info in my reply, but what I'm saying is that I've already typed this at least 10 times and probably moreso in previous threads. There have been MANY asking the same, basic question...
Old Feb 27, 2007 | 02:07 PM
jusa4cyl's Avatar
will try the 8's and see. I trust ur opinion.
Old Feb 27, 2007 | 02:51 PM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Anyone know who stocks the NGK BPR8ES ?
Old Feb 27, 2007 | 05:22 PM
riceball777's Avatar
br's are knows to run better than the prutruding tip bpr's
Old Feb 27, 2007 | 08:32 PM
kjewer1's Avatar
I've posted this in the past, but again for the archives, I've found the non-projected plugs to work very well for avoiding knock. I started testing them when I started running nitrous, with the BR8ES. I get the impression that the shorter side electrode is worth more than the colder heat range. I have had a lot of trouble in the past with knocking the side electrode off even when there is no damage to the rest of the motor otherwise or even any knock picked up by the ECU. I've had two scary events on the EVO that should have taken the plugs apart based on past experiences, but the plugs didn't even show any signs of excessive heat much less any damage. I now run BR7ESs on the street, and I will continue to run the BR8ESs on the nitrous. I see no measurable negative side effects to running the non-projected tips, so I view it as cheap insurance. The 8 heat range however does degrade faster on the street, so I'm not sure BPR8ESs make any more sense than the BR7ESs for most poeple.
Old May 20, 2007 | 07:35 AM
treasure27's Avatar
advance auto part carries BPR8ES
Old May 20, 2007 | 07:40 AM
evo_08's Avatar
bpr9es
