gt35r/stock motor
gt35r/stock motor
I will be doing this gt35r/stock motor
basiclly this is what it will have.
burchur gt35r
hks 280s
FMIC+ pipes
ACT clutch
780cc injectors/255fuel pump
EBC set @ 21psi
TBE
ECU flash
looking to get 400whp..
let me know if there's any other parts i need for this simple set up
burchur gt35r
hks 280s
FMIC+ pipes
ACT clutch
EBC set @ 21psi
TBE
ECU flash
Yup 400whp for a 35r is a waste.
Besdies i think you should think about building your motor.
Ppl say that stock motor is good up to 475whp and ppl have gone above 500 plus but in the end its just matter of time before your engine gives up...
Stock motor with 35r here. Running Meth and 26+ psi. On 20 PSI you will feel a difference over stock but you need to turn the wick up a little. I would recommend going with a meth kit honestly while doing this.
Thats pretty much my setup...and I hit 407whp @ 22psi...It doesnt hit full spool till right under 5k...So its laggy, but it was def. worth it, b/c I am building the car next year, after I push the stock motor...I just didnt have enough money to do it all @ once, so all the parts I put on my car along the way will be able to support my future goals...good luck
i just can't stand to do small mods such as 20g lt+++++ and + mods to get to 400whp and if i wanted to go futher then i have to buy a gt35r then have to sell the 20 g lt..why waste time and money? why can not put big turbo in and have fun for a while then save up some more to get the motor built.
