gt35r/stock motor
Old Mar 5, 2007 | 12:44 PM
WrX Kila's Avatar
Stick with the 35r... you will make 400whp without breaking a sweat. If you get a 50 trim or any other inferior turbo you will be wanting more. TRUST ME! That said...GT35R FOR PRESIDENT!!
Old Mar 5, 2007 | 12:49 PM
Rexpeed's Avatar
i would get larger injectors... get at least 1000cc injectors that way when you do get your 2.3 you dont need to get new ones.
2SloEvo's Avatar
Originally Posted by Evo_Wanted
I will be doing this gt35r/stock motor
basiclly this is what it will have.
burchur gt35r
hks 280s
FMIC+ pipes
ACT clutch
780cc injectors/255fuel pump
EBC set @ 21psi
TBE
ECU flash
looking to get 400whp..
let me know if there's any other parts i need for this simple set up
evo wanted, this is pretty much the setup I have currently, except for a different clutch and 264s instead of 280s. On pump and 21-22 psi it pulls pretty hard but at 26+ psi is where it really hits! like an above poster said you might want to consider meth injection to run higher boost to get more out of the turbo. The 35r isn't a great pump gas turbo, but if you plan on building the motor 35r is great!
jayg4u
Dec 25, 2013 04:47 AM
Dragking2189
Jun 22, 2009 02:26 AM
Strictly Modified
Sep 15, 2008 08:57 AM
evotuner04
34
Jul 29, 2008 09:40 PM
Evo_Wanted
13
May 28, 2007 12:29 PM
