Mods Safe to run Stock ECU
Old Mar 6, 2007 | 07:32 PM
EvoDan2004's Avatar
i had intake, mbc, tbe, bov, fmic, u/l icp and no tune. as soon as i put the forge waste gate, works o2, ported 10.5, ported exhaust manifold on my car did not like it. it was running like crap. real bad. i called jestr and well look below. ****y driver and some nice times.
Old Mar 6, 2007 | 07:33 PM
Warrtalon's Avatar
So what mods can you do with a "non-flashed/tuned" ecu? I have tbe, the injen full intercooler piping, and the turbo xs rfl vta bov right now.. and I'm fine. Atleast it seems fine to me.
It's not fine. That BOV should not be used whether tuned or not, and the intake is doing nothing but hurting your MAF readings without a tune. It makes no sense to spend $400 on an shiny intake yet not have a tune for it. The intake does nothing and the tune gives you 20-30whp - easy choice you would think.
80210 - you really shouldn't do anything without a tune. I don't know why you would want to make a list like that. It's never a good idea, and any mods that CAN be done are still risky for various reasons. Like an exhaust, for example. If you put a TBE on an otherwise stock Evo, it will have a tendency to overboost in cold weather, which triggers fuel cut. This is a bad thing and can cause an overboost code that eventually puts you in limp mode, not to mention the fact you're running way more boost than you should. Similar points can be made for other mods, too.
Ted B's Avatar
Basically anything that doesn't blow up the car constitutes something that 'one can do'. Of course, the potential of those mods (and the money invested therein) will never be realized with the factory tuning, simply because the factory tuning cannot even make the most of the factory equipment.
FYI
Old Mar 6, 2007 | 07:35 PM
Boost3dxEvO's Avatar
Hey man.. thanks for the input.. I was just wondering because I'm about to get a new intercooler, the other lower ic pipe, ported manifold, possibly a new intercooler sprayer, and new 02 housing for the turbo.. I was told I need to get it reflashed after these mods... what do you think???
thanks!!
Old Mar 6, 2007 | 07:37 PM
EvoDan2004's Avatar
thanks!!
lol. YES GET IT FLASHED. OR TUNED
Old Mar 6, 2007 | 07:38 PM
Warrtalon's Avatar
What I think is you are wasting a lot of money without knowing what you're really doing. Of course you'll need to get tuned for all those additional mods at the very least.
Vigo's Avatar
Running untuned is not safe.
Old Mar 6, 2007 | 07:40 PM
Ted B's Avatar
thanks!!
I think you will find that a competent reflash will make more of a difference than everything you've done/spent thus far. Until this is done, it will never run close to its potential.
Old Mar 6, 2007 | 07:41 PM
80210's Avatar
So by telling shiv at vishnnu to tune (I'm looking at getting the mail in v380) for a TBE and air intake... the evo will become safe in all ways, correct?
Old Mar 6, 2007 | 07:42 PM
80210's Avatar
Basically I really want to invest in my car and make it faster but by all means I want to do it safely...
Old Mar 6, 2007 | 07:44 PM
Ted B's Avatar
It will run better than it does now, and generally speaking, that can be interpreted as 'safer', 'tuned', and/or 'more efficient'. If retuning the ECU caused a pattern of issues, no one would bother, and upgrading these cars would be much less gratifying.
Old Mar 6, 2007 | 08:07 PM
Warrtalon's Avatar
That's one option, but we have a local flash tuner, so send me a PM and/or head to RMEVO.com. You are in CO, right? You can get a custom flash locally for less than half of a v380 mail-in. We just had our first annual RMEVO meet and had 30 Evos show up. Did you miss out? Our new local tuner was there flashing left and right.
Old Mar 6, 2007 | 08:25 PM
sparky's Avatar
I don't know what the fuss is? When I sent my piggyback in for an update, I ran around on a stock unflashed ECU for a couple months with the following mods:
280 cams(+2/0)
upgraded FMIC
K&N drop-in
3" TBE
255 WALBRO
S.S.A.C. O2
ported 10.5
AMS L.I.C.P.
DejonTool MBC
I just turned boost down to 17.5#. I think that I ran it daily for two months. No long-term ill effects. I did it out of necessity, since I live outside the U.S. I wouldn't endorse this practice otherwise though. By all means get it flashed for any major mods. The car ran uber-rich, and was very detonation prone, with much higher EGT's and the crappiest fuel economy.
Old Mar 6, 2007 | 08:30 PM
80210's Avatar
Yeah I've heard lots of different things... I'm not sure what to do. Save up my money buy all my mods in one day and then send in the tune so my car is only out of commission for a week?
Keep the inputs or experiences coming, I'd love to hear more.
Old Mar 6, 2007 | 08:31 PM
80210's Avatar
So you had an MBC?
