Wheres all these Cosi Cammed 9's @??
i have
S1 cams
toda manifold
3" tbe
invidia O2
Greddy intercooler
works drop in
greddy profec b spec II EBC
ralli art thermostat
Ecutek custom flash
1.5 bar
419.7 Bhp / 420.8 trq external temp was ~21 'C
my friends car running the high boost....and different cams....is making so much less power than mine after 5500 Rpm...that is why on the street my car is faster...although when i drive his car it feels like it pulls harder...
anyways bosshog...how much millage have you put on your car with this setup at 1.7bar of boost? how do you drive..are you a moderate driver or beat hard on the car?
please let me know ... i am thinking of adding an FP Green...next and raise the boost to ~1.7...
and is your fuel equivilant to 97 oct (relative to us gas or europian)
thanks for the answers....cant wait to take my car to the track next week...
S1 cams
toda manifold
3" tbe
invidia O2
Greddy intercooler
works drop in
Ecutek custom flash
1.5 bar
back to back testing i did and i saw 12-13whp increase on my car on the same Dyno Dynamics with much less bolt ons than other guys and 22psi spike and then i had a leak also from my greddy type-rs bov, which i changed it to the stock unit again until i install the tial unit i got...
he had a crazy leak from the exhaust manifold... from what i remember, he saw ~25whp increase with the cossie cams on the Dyno Dynamics even with the leak, on high boost pressure and meth...
So, who is to say the results came from the cams.
Im sure most, if not all those results came from the alky, not the cams, Again not a good comparison.
Why does nobody have a straight before and after Cosi cam install, without leaks or the addition of other mods...
Only the one works did that only got them 13 whp gain after their tune that's the only one I've seen like that.. And ppl would rather get tuned once not a bunch of times so they throw everything on at once
It just seems that both cams are making that 10-20 whp (being lenient here), ams got those gains from the gsc 1's and al also even said it in his thread he didn't know where people were getting this 30-40 whp gain, he figures 15-20 whp to be normal on the cosworths.
Why do I keep reading threads where people are comparing Cosi's and GSC S1's??
S1's are made for small turbo's..
Cosworth's and S2's are made for bigger turbos..
If you need a larger cam, then consider Cosworth or S2's..
It's like sayin; "I can't decide between HKS 272's or JUN 272's? I mean their the same size right?"
The difference between these two dynoruns is the cossie cams!!!! Yes i had the leaking bov but the leak was there for both dynoruns, meaning before the cam install and after... Its 13whp increase on the Dyno Dynamics at 22psi spike, dropping almost immediately to 21psi and tapering to around 17psi to the redline...
if you people searched and checked carefully you would find this dynochart
Thats a nice increase for just adding cams straight up.
Your before hp curve is much flatter.
