Which intake?
Old Mar 8, 2007 | 12:48 AM
Speed Element's Avatar
ARC intake FTW! https://www.evolutionm.net/forums/sh...d.php?t=252487
Old Mar 8, 2007 | 10:42 AM
Inprogress's Avatar
I'm really happy with my apexi intake, it doesnt replace the maf tube (probably all for good reason) and does its job. I got for just a little over 100 bucks too.
Old Mar 8, 2007 | 10:52 AM
KOEvo's Avatar
Originally Posted by High_PSI
APEXi intake is the best as it cleans the best and doesn't effect the MAF. Buschurs does teh same as well.
Originally Posted by deadbeatrec
im sorry but i have seen many many tests and the HKS filters suck ***.
k and n typhoon intake pipe sucks but k and n filters are great. so are apexi filters.
+1!!!!!!!!!!!!!!!!!!!!!!!!!!!
That's all that needs to be said about intakes.
Old Mar 27, 2007 | 02:34 PM
teamorbit's Avatar
I have a Weapon R secret weapon intake on my 06 Lancer and I cant complain.
It fits good, sounds good and noticed a little more power. Cant tell if its saving me gas but other than that happy with the purchase.
Old Mar 27, 2007 | 03:16 PM
pog0's Avatar
Buschur.
I have the filter installed but waiting to install my MAF pipe after I get my 1g modded by Dejon.
Old Mar 27, 2007 | 11:20 PM
evilevo22's Avatar
apexi intake is the best
Old Mar 27, 2007 | 11:23 PM
RenoEvo's Avatar
Originally Posted by Speed Element
+1
Old Mar 27, 2007 | 11:57 PM
ixsaves13's Avatar
apexi has had the best performance / filtering from an article i read. It did not include the ARC or buschur.
Old Mar 28, 2007 | 12:01 AM
chrismnj's Avatar
Thumbs up Injen 100%
Get Injen For 100% It Is Loud *** Intake And Look Good But U Got To Get It Tuned
Old Mar 28, 2007 | 01:10 AM
Erik@MIL.SPEC's Avatar
+ a google
Old Mar 28, 2007 | 07:44 AM
EvolutionBoy67's Avatar
has anyone used the beat rush air intake box? If so does it really help with supplying the intake with cold air. If you guys dont know what im talking about here is the link.
http://www.speedelement.com/index.ph...mart&Itemid=38
Old Mar 28, 2007 | 08:37 AM
High_PSI's Avatar
I like the heat shield but the filter looks like it'll effect the MAF negatively by causing turbulence. It also looks like it is the kind of filter that needs to be oiled so it'll soon coat the MAF with it and make things worse.
The only filters I know of that work perfectly with the OEM MAF is the APEXi and the Buschur. Their designs both have a funnel that protrudes into the filter which is said to straighten out the airflow and make it uniform. The APEXi unit uses a solid piece of plastic while the Buschur uses a filter material that flows as well. Which one works better? Who knows but they both work very well and both make power over the OEM airbox and both do NOT effect the MAF.
I would not run any filter except the two mentioned above. I personally went with the APEXi unit.
Dave Buschur also mentioned to keep the OEM intake tube as it baffles intake noises which also effect the MAF. The OEM intake tube works very well to stop that and isn't a major restriction so if you use just a filter your daily driver will be FAR less finicky; especially with cams.
Old Mar 28, 2007 | 08:43 AM
Aloosh's Avatar
Go for the ARC filter box those r great i got i in its beautiul and it looks even better
NIevo's Avatar
+1 for the Buschur intake and keeping the stock pipe. I have the hard pipe and my car idles really rough. Am having problems with it dying also. Going to try and tune it better now that I have ECUflash
Old Mar 28, 2007 | 09:02 AM
If i get an intake ill get the buschur racing intake. My question is would adding the beat rush intake box with the br intake make any difference.
