Stalling problems...
Old Mar 7, 2007 | 09:19 PM
kmcknight's Avatar
Ok to be truthfull I haven't actuall stalled yet...
Here's the deal, I recently had my car tuned and all was perfect. I just installed a MBC today and now when I start from a stop in 1st it seems like I am about to stall. It bogs down big time, so now I've been giving it more rpm's everytime I take off.
My MBC is Forge and it's set to approx. 20 -21 lbs. I've checked for boost leaks already and all of my intercooler piping and intake is in place as well... Any ideas as to why now my car is doing this??
Old Mar 7, 2007 | 09:22 PM
AF-Evo8's Avatar
did you have the intake when you got tuned ?
Old Mar 7, 2007 | 09:25 PM
kmcknight's Avatar
Yes everything in my sig was in before the tune except the MBC
Old Mar 7, 2007 | 09:29 PM
big_huff's Avatar
I'd still say its the intake, i'd go back to the stock air box thats just my .02
Old Mar 7, 2007 | 09:31 PM
kmcknight's Avatar
my car has had that intake for over a year now before a tune, and even after the tune it was even better...
now after the MBC, because that the only thing thats changed since today, my car is bogging down from a stop...
AF-Evo8's Avatar
make sure the MAF plug is plugged in all the way, however unlikely you should check Anyways and do you have any thing else done to your car that is not in your sig? Like a BOV, Try the stock airbox too.
Old Mar 7, 2007 | 09:35 PM
kmcknight's Avatar
there's no way that it could be my intake... perhaps the MAF which is worth a double check, but I literally hooked up the MBC today and left the parking lot to slowly raise the boost and I almost stalled, and then did it again like 10 times...
edit. i have the stock BOV
Old Mar 7, 2007 | 09:44 PM
AF-Evo8's Avatar
when you disconnected the factory boost solenoid did you leave the harness plugged in and cap every un-used nipples?
Old Mar 7, 2007 | 09:46 PM
AF-Evo8's Avatar
When i did my MBC i hooked into a Tee off the BOV line and the wastegate and capped the turbo outlet, the intake tube nipple and both of the solenoid connection and left the solenoid plugged in.
Old Mar 7, 2007 | 10:03 PM
kmcknight's Avatar
i plugged it into itself, therefore "capping it"
Old Mar 8, 2007 | 12:48 AM
riceball777's Avatar
make sure you dont have the sotck plastic blow of valve
i swaped out to the forge diverter valve and it fixed all my stalling problems
Old Mar 8, 2007 | 08:22 AM
kmcknight's Avatar
Why would my stock BOV be the cause of my problems?
Old Mar 8, 2007 | 08:31 AM
GHEvo8's Avatar
my bov was leaking and it caused all kinds of iddle/stalling problems
Old Mar 8, 2007 | 08:35 AM
kmcknight's Avatar
Now it's making more sense, when setting up the MBC I hit 25 pounds a couple times, maybe I broke my BOV and now it's leaking maybe??
Old Mar 8, 2007 | 08:42 AM
GHEvo8's Avatar
get a forge its cheap and very decent for the $$
