No oil filter washer from the factory?
Old Jun 4, 2003 | 09:25 AM
Stinkapuss's Avatar
No oil drain plug washer from the factory?
Changed the oil the other day and when I loosened the plug to drained the oil there was no washer between the drain plug and oil pan. Has anyone else had this issue?
Old Jun 4, 2003 | 09:43 AM
wizardofoz's Avatar
Look at the drain plug very closely. I think that on mine that it was painted on to the drain plug so it is hard to see.
Old Jun 4, 2003 | 09:48 AM
Stinkapuss's Avatar
It's not there. The replacement washer that comes with the oil filter is a double ring looking washer and would be very hard to miss if the washer from the factory looked the same. What's funny is that I changed the oil in my 03 Crv for the first time this weekend and it also had no washer.
Old Jul 21, 2003 | 10:17 AM
evo8ove's Avatar
Re: No oil drain plug washer from the factory?
Just did my oil change yesterday.
No washer as well.
Old Jul 21, 2003 | 10:23 AM
Secret Chimp's Avatar
You sure it wasn't compressed almost flat against the drain plug's head?
That double ring looking washer gets crushed down to about 20 % it original thickness once the drain plug is properly retorqued in place.
SC~
Old Jul 21, 2003 | 10:25 AM
mayhem's Avatar
SC~
Yes PLEASE double check that what Secret Chimp isn't the case. I've made a similar mistake with a brake line hose and it started leaking severely a short time later. The washer gets so crushed that it looks like it is part of the plug.
Old Jul 21, 2003 | 10:42 AM
spyderturbo's Avatar
I thoroughly checked mine out when I did my first oil change.
I was pretty paranoid myslef.
but....no...I did not see a washer on there. The filter I bought came with one and I installed that.
Old Jul 21, 2003 | 10:50 AM
Stinkapuss's Avatar
There was no washer and didn't use one this time until I verify that I was given the correct washer (which I doubt). Btw, no washer, no leaks.
Old Jul 21, 2003 | 12:34 PM
weightless's Avatar
Mine had a washer, it was wedge on the oil pan side, I had to yank it out.
