Why you MUST get a tune when you add a air intake to your Evo
Old Mar 14, 2007 | 11:27 PM
  #46
Tha Shocker!'s Avatar
Originally Posted by statix
I was always under the impression that adding a intake would make the car run more rich, not lean it out even more??
I would think so too...knowledgeable ppl please explain...
Old Mar 14, 2007 | 11:37 PM
  #47
EVO8URV8's Avatar
K&N Drop-in filter >>> all intakes
Nuff said
Old Mar 14, 2007 | 11:43 PM
  #48
sickzofive's Avatar
the drop filters are the best and safest and boosting your hp.. my 2cents
Old Mar 14, 2007 | 11:44 PM
  #49
JohnBradley's Avatar
Reread page 2 for your answers.
Old Mar 15, 2007 | 12:25 AM
  #50
Frenchy4g63's Avatar
And people wonder why Mitsu denies warranties "just because of an intake"
Old Mar 15, 2007 | 12:39 AM
  #51
LilRico's Avatar
Thanks AL!
I'll make sure to tune my IX as soon as I get all my toys installed... Thanks AL!
Old Mar 15, 2007 | 02:05 AM
  #52
dbsears's Avatar
Im amazed how many people think the drop in is the best...it may be the safest but it is far from the best. Many intakes will put out much more power than dropins. Go look how many buschur or ams cars run intakes.....nuff said
Old Mar 15, 2007 | 04:49 AM
  #53
mistersquishi's Avatar
I'm sorry but has anyone else noticed what kind of power this was putting down?!? 258 with just an intake on a VIII, on a dynodynamics? Should be over 200 for sure but not over 240.
If so this is one HELL of an intake.
Old Mar 15, 2007 | 07:58 AM
  #54
CaymanEvo3's Avatar
This thread has been beaten to death IMO.
Old Mar 15, 2007 | 11:58 AM
  #55
porque's Avatar
Does replacing the stock airbox with a cone filter, such as the Buschur filter cause problems? I'm not talking about the whole intake system, only the filter.
Old Mar 15, 2007 | 01:29 PM
  #56
l2r99gst's Avatar
Originally Posted by DynoFlash
A proper tune will add fuel to adjust for the distortion of the MAF signal by the aftermarket intake and provide a safe a/f througout the power band
Don't forget about closed-loop fueling, either. Using the open-loop fuel tables is fine for tuning open-loop. For closed-loop (cruising, part throttle), you should also be tuning the MAF scaling table to adjust for the altered airflow reading through the MAF. The stock MAF scaling table has adjustments for up to 1600Hz.
If not, you can possibly have your fuel trims off by a large enough percentage to cause issues with transitions from closed to open loop. Worst case would be a maxed out fuel trim where you could run too rich/lean during cruise, causing a fuel trim cel and possibly dropping into open-loop during cruise.
Eric
Old Mar 15, 2007 | 01:48 PM
  #57
madmax199's Avatar
I'm also curious as to why this car is making so much power on a DD dyno with just an intake, broken ring land as a baseline run? Something is fishy with this dyno chart or the whole story is not told. How much boost was he running, what other mods, and what grade of fuel was this freak on?
Old Mar 15, 2007 | 04:35 PM
  #58
dbsears's Avatar
Thats what I have been saying, whats up with these dyno numbers. If it runs sooo bad how the hell did it make 260WHP . I think this just shows his numbers are never as good as everybody thinks (Also why buschur products always gain like 30WHP ) Anything looks good when you control the correction factors.
Old Mar 15, 2007 | 04:44 PM
  #59
GPTourer's Avatar
I understand the detrimental effects an intake can have on MAF, but assuming that there were no other factors in causing damage to this car is not right. Unless the car was documented over those 20K miles.
KevinD
33
Jan 16, 2017 01:19 PM
Evo11V
107
May 9, 2005 11:07 PM
SuperHatch
231
Feb 14, 2005 03:50 AM
