Silkolene?
Old Mar 15, 2007 | 08:24 AM
Bonestock!'s Avatar
Silkolene?
Curious if anyone is using Silkolene syn 5 gear oil in their trans? I haven't been able to obtain BGII in the UK and it can't be mailed via USPS. I figured this stuff has a very good rep here. Anyway check it out:
http://www.performance-oils.co.uk/acatalog/Gear.html
Silktran Syn 5 Gear Oil
A fully synthetic gear oil lubricant for manual transmissions and final drive units in high performance vehicles. Operates over a wide temperature range. Gives true "stay in grade" performance. Enables optimum power release; even at low temperatures. API; GL4/5; SAE 75w/90
My 8k mile 2005 VIII GSR has the infamous 5th gear grind and I want to give a fluid change a try between now and when Mitsu USA gets their hands on my car in Oct.
Old Mar 15, 2007 | 08:26 AM
RoughedgesMR's Avatar
i dont know about their gear oil but formula 1 cars use their motor oil. VERY expensive stuff. My friend also runs it in his gt3 944 turbo race car.
Old Mar 15, 2007 | 08:32 AM
Darwinian's Avatar
Looks like it is available here http://www.silkoleneshop.com/products/oil/gear/
Bonestock!'s Avatar
Yeah its expensive. I just spent around $60 for 3 liters of this stuff!
Old Mar 15, 2007 | 09:26 AM
CO_VR4's Avatar
I thought the transmission took only GL-4, and GL-5 was not recommended for transmissions, although it was OK for transfer cases and rear diffs. Is that wrong?
Old Mar 15, 2007 | 11:45 AM
Bonestock!'s Avatar
You have to look at what the product description on their website. It says its ok for both, hence the GL4/5 rating.
I just changed the fluid. I was pretty surprised by the amount of metal on my drain plug. Even more so when you consider I only have 8,000 miles!!!
Also, changing the fluid on Evo's suck compaired to my old WRX. I am gonna have to buy a fluid pump. That would make it much easier.
Shifting: I only drove the car from the hobby shop to my house (1/2 mile) but even cold it shifts better than the stock stuff. I'll update once I actually get the car up to speed.
Old Mar 15, 2007 | 11:52 AM
CO_VR4's Avatar
GL-5 fluid will attack brass parts. It may meet the fluid specs, but is contraindicated if it is a GL-5. Mitsubishi specs a GL-4 and is VERY specific that it is Diaqueen or an identical product.
Old Mar 15, 2007 | 11:56 AM
Bonestock!'s Avatar
http://www.silkoleneshop.com/product.../15250105.html
I just did some checking and nearly all the big names here in the UK say its what the use or recommend (this or Millers CRX).
Old Mar 22, 2007 | 04:09 AM
Bonestock!'s Avatar
Well I have been running with the Silkolene for about a week now. First off, why couldn't mitsu add a dipstick like Subaru??? What a PITA, I really need a fluid transfer pump!
Cold shifting still sucks. I don't get a grind but the shift is very notchy.
Warm shifting GREATLY improved. It seems to get better the longer the Silkolene is in.
The BIG one.... 5th gear grinds hardly at all now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 22, 2007 | 04:10 AM
Azntoyhere's Avatar
This is prolly a false statement, but OIL is OIL ^_^ !! i dunno, might try them.
gregoryhouse
Lancer Tranny/Drivetrain Tech
Jan 10, 2015 09:39 PM
dambikeracer
215
Jan 31, 2011 09:50 PM
boostedspra
Feb 19, 2008 05:33 PM
lancer2show
Lancer Aftermarket Forced Induction Tech
15
Nov 2, 2007 09:58 AM
Denverwhitetrac
Feb 27, 2007 09:10 AM
