o2 Housing/Downpipe install
Old Mar 15, 2007 | 05:02 PM
MFactor's Avatar
I'm using an Invidia o2 Housing and an XS Power downpipe and it seems to be a few mm off from fitting or is this how this flange is supposed to fit?
Thanks for the help in advance!
Old Mar 15, 2007 | 06:04 PM
Luis@TTP's Avatar
thats how its supposed to fit the down pipe will not cover all of the exhauts gasket. it will only pinch it to make a seal or fit really snug once you tighten it up. there are only two i believe that dont use any gasket at that joint one is from bushur and one is from megan but its only a certain megan.
Old Mar 15, 2007 | 06:05 PM
Evo8yurAMG's Avatar
that is rediculous if that is how it is supposed to fit...
Old Mar 15, 2007 | 06:59 PM
MFactor's Avatar
Yah...I'm pretty skeptical about it too. There's about a 5mm gap...which would probably drop another 2mm once I bolt it together...but still not sure.
Old Mar 16, 2007 | 01:42 PM
MFactor's Avatar
anyone else? Maybe someone that's used an invidia?
Thanks
Old Mar 16, 2007 | 01:46 PM
Redline06's Avatar
yeah.. that's how is suppose to fit.. dnt sweat it.. i got the ebay one with a JIC DP one.. and yeah it will sit more once you make it tighter.. I was myself doubting too.. but after hearing no leaks.. I was.. Whatever.. okay.. drove off and had fun..
Old Mar 16, 2007 | 01:47 PM
Redline06's Avatar
Old Mar 16, 2007 | 01:57 PM
RazorLab's Avatar
That is how it's supposed to fit. The donut gasket acts like a joint so the downpipe can shift around if needed.
Old Mar 16, 2007 | 09:49 PM
Luis@TTP's Avatar
this is how it is suppoesed to fit. its not ridiculos its how all car companys make these things when u have that kind of gasket they never cover the entier thing. those gaskets were made to be compressed to seal not swallowed by the downpipe. this is how it sits in there if you put it on and tighten the down pipe on that gasket it should not leak unless you have a bad gasket.
Old Mar 17, 2007 | 12:05 AM
MitsuJoe's Avatar
Remove the brass ring and it may fit better. I had to do this with my Invidia O2/Works DP.
Old Mar 17, 2007 | 12:10 AM
Steve@NoLimitmotors's Avatar
its fine, that show they fit, theres a gap, but it seals fine, I think theres even a gap with the stock one
Old Mar 23, 2007 | 07:34 PM
EvoInvidia's Avatar
you can take off the brass gasket, but its better if you use it, and yes. that is how it fits. the spring bolts help tighten the O2 and DP together. see how they arent regular bolts..
MFactor
For Sale - Cars For Sale
16
May 17, 2007 07:52 AM
MFactor
Mar 26, 2007 07:11 AM
Mike@Forge
16
Feb 22, 2007 02:35 PM
Mike@Forge
97
Oct 3, 2006 02:20 PM
Jakeg97
Feb 8, 2006 12:15 AM
