Stock o2 housing port job?
Old Mar 18, 2007 | 07:31 AM
PcK EvO's Avatar
hey whats up fellas, got a quick question. Is it possible to have the Stock o2 housing ported, and if so, is it worth the while or should i just get an aftermarket one? thnaks for any help
Old Mar 18, 2007 | 07:38 AM
Aby@MIL.SPEC's Avatar
i would buy a aftermarket, as the effort towards getting the i.d of the oem o2 housing as large & concentric as a megan o2 housin just isnt worth the time.
you can buy used o2 hosuings for ~60 or new for ~110. It's just not worth the effort IMO.
Besides, i am a cheap bastard too & I would buy 1 instead grinding & machining a oem housing.
Old Mar 18, 2007 | 07:42 AM
Dead-Man Inc's Avatar
go ahead and buy a brand one
the Ebay 02 housing .. very cheap
Old Mar 18, 2007 | 01:37 PM
DanJ's Avatar
I would now be weary of the 02 housings sold on ebay now. It seems the quality has dropped on them.
Old Apr 16, 2007 | 06:31 PM
mifesto's Avatar
i'd be careful w/ ebay o2 housing... labor to get them on isnt cheap.
Old Mar 11, 2008 | 02:55 PM
mrfred's Avatar
Does any have the I.D. measurement of the stock O2 housing outlet? Anyone know how much wall material can safely be removed?
Old Mar 11, 2008 | 03:42 PM
9sec9's Avatar
I'll measure our original stock ported O2 housing. I think this is a pic of it after I matched it to the turbine housing.
Old Mar 11, 2008 | 03:46 PM
9sec9's Avatar
Sorry, I looked at the O2 housing that's here and it's bascially just a clean up job on it. Not truly ported.
Old Mar 11, 2008 | 03:52 PM
9sec9's Avatar
I checked our 'cleaned up stocker' and it measures 2.513 on the dial caliper.
Old Mar 11, 2008 | 03:56 PM
mrfred's Avatar
Thank you. Do you have any feel for how much wall thickness can be removed in the last few inches?
Old Mar 11, 2008 | 04:00 PM
mrfred's Avatar
What grinding tool did you use? I'm thinking of picking up a Rotozip for the job.
Old Mar 11, 2008 | 04:05 PM
Slo_crx1's Avatar
I've always used an air dremel type of tool with carbide sanding rolls for cast iron and steel.
Old Mar 11, 2008 | 04:06 PM
9sec9's Avatar
rotozip will get worked to death. I use carbide cutters and a makita 6.5 die grinder. It turns 20,000 rpms I believe and the carbide makes short work of just about anything. Are you talking about the first 2 inches at the turbin end, or the dp end? I'll look close and measure.
Old Mar 11, 2008 | 04:08 PM
9sec9's Avatar
I use the same type barrel rolls for the sanding step. Final step is up to you and the finish you want. 120 is about as fine as I go.
Old Mar 11, 2008 | 04:18 PM
mrfred's Avatar
Thinking the most value is at the DP end. I would imagine the turbine side is already pretty closely matched to the turbine outlet, and plus, I'm was thinking that I would port the housing without removing it, so no chance to hack away on the turbine side.
