Torque-split clarification...
Old Mar 22, 2007 | 12:44 PM
amstel78's Avatar
Originally Posted by Vigo
They are wrong.
From the EVO drivetrain for dummies thread:
https://www.evolutionm.net/forums/sh...d.php?t=149737
Originally Posted by SuperHatch
From the best I can gather looking at the systems mechanical design, and not being in any way affiliated with Mitsu and therefore not knowing the system as intimately as their designers...
The maximum torque split is 50/50, and that occurs when the VCD/ACD is completely locked up. The thing that intrigues me, is that I don't see a physical way of resricting where the power goes, when the VCD/ACD is partially/fully unlocked. IE, there is no limiter telling more power to go to the front or rear. If the VCD/ACD is at 90% lockup, then 5% more torque will go to one end and 5% less to the other, but there is no determinig factor as to which end of the car would get more or less.
Admittedly, I'm having a hard time visualizing this system in action, and that bothers me somewhat I'm going to keep thinking about this and I will have a more definitive answer to you.
My instinct right now is telling me that the center diff acts like a rear diff in a pegleg car, such that there is a normal mechanical tendency for one side to spin than the other. Mitsu may have designed the system with this in mind, and the end of the car they instinctively want to get more power is attached to the side of the center diff that "sees" more torque. If this is the case, at full lockup the car is 50/50, and if the front diff is on the high-torque side of the center diff than when the VCD/ACD is unlocked, the car acts as FWD. So a partial unlocking of the VCD/ACD can result in a 60/40, 70/30, whichever amount desired torque split. However, there can never be more than 50% of the torque going to the rear wheels.
As I said, this is just a theory at this point, I'm going to think about this more...
- Steve
So it seems we are all confused...
Old Mar 22, 2007 | 05:43 PM
EVOlutionary's Avatar
Originally Posted by BigEasy0420
Wouldn't changing the clamping force via the ACD selector switch technically change the amount of torque being distributed rearward.
No.
The correct answer here is "depending on conditions, yes, but not necessarily" .
Old Mar 22, 2007 | 05:57 PM
Don't necessarily believe everything you read:
The maximum torque split is 50/50, and that occurs when the VCD/ACD is completely locked up. . . . .
Incorrect. 50/50 torque split occurs when the ACD is open/disengaged.
. . . . My instinct right now is telling me that the center diff acts like a rear diff in a pegleg car, such that there is a normal mechanical tendency for one side to spin than the other. Mitsu may have designed the system with this in mind, and the end of the car they instinctively want to get more power is attached to the side of the center diff that "sees" more torque. . .
Correct. I believe this is why the car exhibits FWD tendancies, just like my '99 Dodge Ram 2x4 exhibits "left wheel drive" tendancies. Maybe it could be called a 49:51 split ??
. . . . If this is the case, at full lockup the car is 50/50, and if the front diff is on the high-torque side of the center diff than when the VCD/ACD is unlocked, the car acts as FWD. So a partial unlocking of the VCD/ACD can result in a 60/40, 70/30, whichever amount desired torque split. However, there can never be more than 50% of the torque going to the rear wheels.
- Steve
Incorrect. If you have the front wheels on jack stands and the rear wheels on dyno rollers, when the ACD is engaged 100% of the torque is tranmitted to the ground by the rear wheels up to the mechanical limits of the ACD clamping force.
The opposite is also true. . . so the ACD equipped center diff in the EVO can put down torque to the ground anywhere from 100:0 to 50:50 to 0:100 (up to the mechanical limits of the clamping force of the ACD clutches)
EVOlutionary
Old Mar 22, 2007 | 07:12 PM
amstel78's Avatar
EVOlutionary
This is turning out to be a very interesting discussion... perhaps one of the mods could transfer it to the tech/drivetrain section?
Regarding this last paragraph of yours; I find this statement very very intriguing. Do you happen to have a link to any whitepapers discussing this? It seems everything I've read (here on the forums, and on the web) contradict what you've just written. At this point, I think I'm more confused about this subject than when I first started reading.
How does Subaru's DCCD function in comparison? Is it fixed at 41:59, whereas your claim leads me to believe that 100 percent of the torque could be either shifted front or back depending on situation?
P.S. Some really interesting reading here. Haven't gone through all of it yet, and not quite sure how accurate the material is, but entertaining nonetheless: http://www.autozine.org/technical_sc...action_4wd.htm
Old Mar 22, 2007 | 07:50 PM
I don't know if I'm right from a technical standpoint, but the way I work it out with logical reasoning that is the way it seems to work.
Old Mar 22, 2007 | 07:53 PM
amstel78's Avatar
Well hopefully more people can chime in, as this is a topic I'd really like to clear up and understand. As it stands, it seems most here aren't 100% sure how the ACD handles torque bias, and I believe it would be beneficial to the EVO community to get a definitive answer.
Old Mar 22, 2007 | 08:36 PM
lemansz's Avatar
I second Evolutionary... from a logical reasoning standpoint.
Old Mar 22, 2007 | 09:43 PM
RoadSpike's Avatar
First off DCCD Reference:
http://wallace.as.arizona.edu/~cgrop.../DCCD_FAQ.html
How i understand it:
Now the gearing of subaru's DCCD system is 35/65 front/back. This means while open if the engine was producing 100ft/lbs of torque 35lbs obviously would go to the front wheels and 65lbs would end up in the rear.
Now the DCCD system uses a LSD to control the transfer of torque from the rear to back using complex adjustable clutches. Its Important to understand that LSD can't transfer torque without a speed difference. Furthermore the differential will only be able to transfer the torque split between the two shafts even at 100% lock.
If you were to say lock the DCCD at 100% you could get a maximum torque split of 20/80 , thats because its transferring the available 15% difference to the rear or in the case of the rear slipping a max of 50/50. Of course the Evo doesn't work quite in this manner
The Evo:
If the front wheels are spinning faster than the rear wheels, then the ACD begins to lock the clutches up. If the amount of force exerted by the front wheels is less than the amount the clutches resist, then the slip is stopped and both front and rear spin at the same speed. However, if the force the clutches can resist is less than the force exerted by the slipping set of wheels, then the wheels will slip, but only by how much remaining force the slipping wheels overpowered the clutches with.
This is of course exactly as evolutionary put it, I believe people are just having trouble with how an LSD really works and thus I'm going to post a link to howstuffworks.com
http://auto.howstuffworks.com/differential4.htm
Edit:
Hope that clears up some of the confusion here
Old Mar 23, 2007 | 10:27 AM
amstel78's Avatar
^^^ OK, so it's starting to make sense now, but still one thing about ACD seems iffy to me. As EVOlution stated in his previous post, if the front end of the car for example where to be on jackstands, and the rear wheels where on dyno rollers and throttle was applied, then theoretically the ACD would transfer 100% of the torque to the rear wheels? I would then assume that the front wheels would be stationary, or at the very least spinning a lot slower than the rear.
If you were to reverse the position of the jack stands, and the front wheels are now on the rollers whereas the rear are elevated, then the ACD would transfer 100% of the power to the front wheels. Then finally, once both wheels are on the surface, depending on slippage the ACD can vary the amount of torque sent to each axle up to a 50/50 ratio.
I suppose then DCCD is different in function, as the torque split is physically limited to 35:65 or 49:51 (depending on MY), and the driver can lock it to a full 50:50 split by use of the interior control. The DCCD would not variably split torque 100-0-100 as in the case of Mitsubishi's ACD. I would assume then that the ACD system is superior in design to Subaru's DCCD offering?
Am I correct in my understanding?
Old Mar 23, 2007 | 10:40 AM
RoadSpike's Avatar
No thats not how it works.
The lock up of the diff would create a solid axle forcing both axles to move at the same speed. This would happen at loads that do not exceed the clamping force of the center differential once you mechanically exceed the pressure plates the axles would then spin at different rates.
I think thats how people get confused about this torque bias thing.
The DCCD has a mechanical advantage to transfering the torque to the rear wheels so in that primary case the DCCD's system would be advantageous. While we sit at the mercy of how much are diffs locking plates can take . Simply changing our CD's gearing to the 35/65 system would essentially put us on level playing fields.
Old Mar 23, 2007 | 11:05 AM
PVD04's Avatar
I think a major source of confusion comes from people trying to think of the system as "sending" torque to either the front or the rear wheels. If you look at it as an issue of relative wheel speed and the center diff is trying to keep both the front and rear wheels spinning at the same speed it gets a little easier. If the front wheels have 0 traction, then the center differential will attempt to lock and all of the torque will go to the rear wheels. If the rear wheels have 0 traction, the opposite will happen. The torque split is essentially controlled by available traction. The only limit to this is the amount of torque the center differential can support, and beyond that limit the differential slips causing the wheels with limited traction to spin.
-Paul
Old Mar 23, 2007 | 11:17 AM
amstel78's Avatar
Thank you everyone for helping me understand this. I guess the folks over at Car and Driver do have it wrong then by claiming a front bias. It's misleading on their part. It honestly lead me to believe at first that the EVO was essentially a FWD vehicle, then only sending power to the rear when needed. I have noticed a little bit of torque steer, but not what I would normally associate with a true FWD vehicle. Good to know.
Regards
James
Old Mar 23, 2007 | 01:53 PM
Regards
James
Just FYI, I had my car set up last year with a big front splitter and stock rear wing. It made so much downforce and traction in the front that in corners my car acted more like a RWD car. When accellerating through a corner the rear would lose traction first and oversteer, rather push like most EVOs.
While differentials and mechanicals can make a car handle a certain way, so can suspension tuning. . . just something else to keep in mind. . .
Terry S
334
Jan 16, 2016 01:28 PM
gtr
Jan 9, 2005 02:32 PM
Bednbreakfast
Mar 5, 2004 04:58 AM
chopdaddy
Jan 3, 2004 10:01 PM
wtz
Jan 17, 2003 01:24 PM
