Engine building pressure
My engine is building pressure and pushing coolant over the surge tank while im driving. I checked the radiator, and the cap. The whole issue started when my lower hose blew, The car ran hot a little. I was thinking it might be the head gasket, but the radiator ran ok. HELP PLEASE anything
i don't know if its your head gasket. if ur head gasket is bad u will have water or coolent in ur oil. sounds more like a line or a cooling port some were is cloged. not en expert on how the car cools i just know what happens when a head gaskets starts to go bad.
But what i dont understand is how my hose would burst. There had to have been pressure being built up from before. Because i just had the engine rebuilt. Is bursting hose a common issue with evos?
Sounds like you fragged your headgasket.
You also probably have an air bubble in the the coolant. Buy a couple of jugs of coolant, and run your car with the radiator cap off. It'll probably get messy so be prepared.
You'll need to run the car until it warms up with the cap off. What will probably happen is coolant will over flow out of the radiator for a second or two, then the level will drop suddenly. When that happens add coolant. This will probably happy several times, so you may just want to take it somewhere and have them do a coolant flush and fill. It'll be easier on you and less messy that way.
The radiator is off now, so i was going to test the water flow threw the engine to make sure there was no blockage in the engine. I will run water threw the upper radiator block connection, and see if it runs out of the bottom. Because i ran the car with the cap off and it overflowed, and went back down, and i refilled, but it never shot out or anything.
It should never "shoot out". You just keep following the procedure until the flow levels off and stays that way. Sometimes its helps to squeeze the hoses a little. You may have to add fluid several times to get all the air out of the lines. If you can run the car for a solid 5 minutes without it overflowing then dropping suddenly, all the air is probably out of the lines.
It can take 10-20 minutes of running the car before things fully settle down. There are a lot of nooks and crannies for air to get trapped.
sounds like the HG to me also. I blew a coolant hose that feeds the throttle body, but not one of the main ones going to the radiator. My coolant hose blew at about 52K miles. How many miles on your 03? It is recommended that you replace your coolant hoses at 60K per the manual.
