Turbo Timer Harness - MT-1 vs MT-6 - Am I screwed?
I was shipped an MT-1 turbo timer harness for use on an Apex'i TT.
I understand that for the CT9A chassis, the MT-6 is indicated as the proper harness. The MT-1 connector looks like it will interface with the Evo.
Does anyone know if I can simply look up the wiring specs and swap out the pins in the connector, as appropriate? Or, even better, does anyone know which pins I should swap?
Your help is much appreciated.
I have read a lot about people swapping the green and blue pins on the MT-6 to correct problems so I am wondering how different the MT-1 really is.
As for swapping the pins, it is super easy...you just poke the pin out of it's segment and them move it somewhere else.
If someone has a picture of the MT-6 that would also be appreciated!
Thanks for the input...looks like I might be in the same boat.
Anyone got the MT-1 to work with some rewiring?
740 Turbo Brick
May 7, 2014 05:37 PM
