smoke while on 2step?
Old Mar 25, 2007 | 03:39 PM
GT35REVO8's Avatar
well i tested my 2-step the other day..and when i got to 5,500rpm my 2step started and i started letting out a lot of white smoke..it only does this on 2 step..
whenever im at 8k redline and full boost i get no smoke,only on 2step...
anyone know what it could be?car runs fine tho..
maybe its ok,im not sure,ive only tested my 2step maybe 4 times
thanks
Old Mar 25, 2007 | 04:22 PM
2StepsAhead's Avatar
Is the car new? You sure the smoke is white? White smoke usually means coolant, but when you're on the 2step you're dumping a lot of fuel and the smoke usually is more of a black color.
Old Mar 25, 2007 | 05:00 PM
GT35REVO8's Avatar
pretty sure its white..the car is a 05 with about 31k miles...mods are in my signature
Old Mar 25, 2007 | 05:34 PM
dbsears's Avatar
You already have head studs or I would say maybe headgasket if white smoke. You check the coolant lately to see if you have used any.
Old Mar 25, 2007 | 11:34 PM
IntegxX's Avatar
WHen i first got my 2 step the same thing happened to me. After about 6 or 7 times the white smoke went away. Its most likely coolant thats shooting out of a line somewhere maybe cause a line is loose or not clamped all the way. Check out all your coolant lines and also around ur head gasket like dbsear87 said.
mace1890
Lancer Engine Tech
Aug 14, 2015 03:34 PM
CFMP RAblue
Mitsubishi TC-SST Discussion
Sep 20, 2014 03:02 PM
Evojj25
Nov 21, 2010 02:09 PM
Brewster
Oct 26, 2008 06:23 PM
Markley02
30
Jun 13, 2008 07:43 PM
