How to do a Teach in/Relearn Via 2.0 Tactrix for replacement of clutches
Old Sep 20, 2014 | 03:02 PM
CFMP RAblue's Avatar
I am going to do a bit of copy and paste and add a few things that are not in the manual
This function allows the user to execute TC-SST [*] re-learn process that is
necessary in case of the following service.
1. Mechatronic assembly part replacement
2. Clutch assembly part replacement.
Note - This function is executable for vehicles equipped with TC-SST only.
PassThru CAN required and can be found with install instructions here > https://www.evolutionm.net/forums/09...h-tactrix.html
Step 0 - Start car, Transmission in Park.
Step 1 - Ensure no CELs are present (must clear CEL if present), Launch PassThru can and Click on PassThru Can Teach-in. Read prompt and only the brave who understand the consequences will continue
You are now in the Command selection screen
Step 2 - Ensure you have "Diag. Version: 0001" or higher ie 2, 3 etc (if you have vr 0000 read the manual as you have to do extra stuff)
Step 2.5 - E-brake up and fully depress the brake pedal.
Step 3 - Select "Clutch Ventilation" and click the green check mark. A confrimation screen pops up, check mark to continue. Once done, an "Executed" screen will appear.
Step 4 - Select "Stroke Teach-In" and click the green check mark. A confrimation screen pops up, check mark to continue. Once done, an "Executed" screen will appear.
Maybe Step 4.5 - I have issues with the next step failing(Step 5), so I have had to shut the car off and turn it back on at this point.
Step 5 - Select "Boost Teach-In" and click the green check mark. A confrimation screen pops up, check mark to continue. Once done, an "Executed" screen will appear.
Step 6 - Select "Reset Clutch Gain" and click the green check mark. A confrimation screen pops up, check mark to continue. Once done, an "Executed" screen will appear.
Completed!!
Now some else told me that during step 5 the car revs to 4k and stays there for 2 minutes... I am not sure if this is correct as it has worked/executed without that happening to mine.
Now this is what I was told and how I did my teach in and everything seems to be working, if I did it wrong please post or PM me and I will change it.
Cheers/Enjoy
File Type: pdf
crak
906
Aug 14, 2022 02:41 PM
joel794613
Mar 10, 2021 08:47 AM
rawkus123
Aug 8, 2017 12:26 PM
trinibt65
Jul 21, 2017 11:14 AM
rawkus123
Jul 20, 2017 05:19 AM
