what does you boost taper to?
Old Mar 30, 2007 | 01:06 PM
  #31
Wallesasuaz's Avatar
I don't know yet.. I have to put on my boost gauge....
to be continued....
Old May 6, 2007 | 11:41 PM
  #32
Ralph's Avatar
Hardcore Tapering...... (Update) Map Verified
28 PSI @ 4000 RPM - 20.5 @ 7000 RPM
Increase boost..... and
30 PSI @ 4000 RPM - 20.5 @ 7000 RPM
I am going to guess I have a major boost leak... Going to do some tests soon .
I should be able to hold more than that..... since people like ElectricEvoIX spikes less and holds more . Grr. Probably explains my low traps at the track .
Old May 6, 2007 | 11:48 PM
  #33
Ralph's Avatar
After a little more reading I see we can adjust the stock WGA arm and hold some more boost? Any of you guys holding high boost, have to do this? (MBC guys)
Old May 7, 2007 | 12:22 AM
  #34
vboy425's Avatar
Warrtalon you're a ****tard so STFU already.
Old May 7, 2007 | 05:36 AM
  #35
badboybr09's Avatar
STOCK - 20Lbs
Old May 7, 2007 | 05:41 AM
  #36
mifesto's Avatar
hallman mbc ... 22-ish psi and holds.. maybe drops .5 psi
Old May 7, 2007 | 05:52 AM
  #37
Rez90's Avatar
34 pounds at 8k
Old May 7, 2007 | 08:36 AM
  #38
JDMevoBOOST's Avatar
in 85 degree temps at sea level i'm boosting 17psi tapering to about 12.....got a leak somewhere....need to switch to T-bolts and I am 100% stock
Old May 7, 2007 | 02:10 PM
  #39
sonicnofadz's Avatar
I hit 23 and it never tapers. (I use a hallman MBC)
Old May 7, 2007 | 02:45 PM
  #40
modvp's Avatar
I hit 22-23 psi peak and tapers to 19 (controlled by Ecuflash). Mods are HKS 264 cams, K&N drop-in, espelir dp, invidia 3"exhaust, megan resonated test-pipe, stock 03 turbo with 9.8 hotside, Walbro 255.
Old Nov 8, 2007 | 05:57 PM
  #41
cinek's Avatar
mine spikes to 25-26psi and tapers to 20psi with hallman pro rx
Old Nov 8, 2007 | 06:13 PM
  #42
fastrob691's Avatar
Im in your boat, higher elevation, does not matter what I spike to holds 19.7 at 7000, 18.5 at 7500, but nice 25 through the middle. But always seems to be the same at high rpm no matter what the peak boost. I travel between 3100-4200 feet. I have the forge as well. My friends stock IX with a flash hits 19 tapering to 16, he would taper to 14 before the flash. He was excited the other morning with the cold air held 17 psi.
Old Nov 8, 2007 | 06:18 PM
  #43
k2boarder3187's Avatar
using defi mine spikes at 23 holds at 22
Old Nov 8, 2007 | 06:29 PM
  #44
alan678's Avatar
Greddy EBC, 20g-IX-5 (FP EvoGreen) on pump gas (91 oct)
Old Nov 8, 2007 | 06:30 PM
  #45
Kordyte's Avatar
Profec B-spec II, bolt-on car (intake/tbe/fp), tuned for 110 oct: 29 peak, 26 hold. Yeah that's high, I know
