EVO 8 Cam Gear Fittment Applications
Old Mar 28, 2007 | 11:13 AM
Tha Shocker!'s Avatar
I've been currently searching for some affordable cam gears for my 8 and when I come across many advertisements online they also show to fit the 1990-1999 Elcipse GST, GSX Turbo, 1990-1994 Plymouth Laser 2.0L DOHC, and the 1990-1994 Eagle Talon 2.0L DOHC. But I never see it vice versca, so my question is will cam gears made for the above applications also fit on the 2003-2005 EVO 8??
Old Mar 28, 2007 | 12:24 PM
sonicnofadz's Avatar
Personally I would just go with the AEM or Helix gears. Stay away from the HKS gears.
Old Mar 28, 2007 | 12:31 PM
Sap12687's Avatar
Never heard anything bad about HKS' gears.
Old Mar 28, 2007 | 12:35 PM
anjapower's Avatar
Yes, they'll fit but the timing marks are different depending on whether the gears are being installed on a DSM or Evo.
Old Mar 28, 2007 | 09:19 PM
Same here...what's wrong w/HKS
Old Mar 28, 2007 | 09:23 PM
so what your saying is that by installing them on an Evo you wouldn't be able to adjust timing accurately by their marks (and are pretty much useless)?
Old Mar 28, 2007 | 09:32 PM
Ted B's Avatar
I seem to recall some having trouble with gear sets that have only three anchor points (e.g. HKS). You may want to research this.
Old Mar 29, 2007 | 05:59 AM
anjapower's Avatar
No, they will work fine on either application it's just that there are different timing marks depending on whether you are using them on a DSM or Evo.
Old Mar 29, 2007 | 10:29 AM
Ok so, if i bought a set of DSM cam gears and isntalled them on my Evo and wanted to set them to -3,-3 what would the marks need to be set at?
Old Mar 30, 2007 | 10:39 AM
can someone please explain HOW i can properly adjust my cams with DSM gears? What are the timing mark differences?
Old Mar 30, 2007 | 12:29 PM
3deep's Avatar
I think the timing marks are the same but they have a different dowl hole to position the cam.
Old Mar 30, 2007 | 01:13 PM
anjapower's Avatar
correct.
Old Mar 30, 2007 | 01:23 PM
moreryce's Avatar
is the dowel supposed to be in the middle or a lil offset for the evo?
Old Apr 2, 2007 | 09:46 AM
...so if the dowel hole is different on a DSM wouldn't it misposition the cams on a EVO?
Old Apr 2, 2007 | 10:48 AM
anjapower's Avatar
there are multiple dowel holes...
