anyone make a maf adaptor to fit a 4 inch cone?
running a gt series turbo with a 4 inch intake.... anyway i can run a air filter that has a 4 inch opening on the maf? thanks for reading.
you lost me..
youre going to need to taper from the 4" gt inlet to the 3" MAF outlet.. most of the maf inlet adapters are 4.5" or so... check out vibrantperformance.com
cb
cb
You know that you will not gain anything from going from a 3" intake to a 4" intake on a turbo that has a 4" inlet..
With that being said, you can simply get a reducer to go from 4" to 3" at the maf, and just get a K&N filter which is the size you are looking for.
I see what you are doing. here is exactly what you will need
This will go after the maf to attach the intake:
http://vibrantperformance.com/catalo...cfec2e619ac562
and this will go before the maf and attach to the intake pipe:
http://www.samcosport.com/us/reducers.asp
You can get one from Pep Boys. I bought my 4inch MAF adapter there for $12. It was for an Eclipse but fits the MAF perfectly. Look in the section where they sell those cheap air intakes and cone filters, you should be able to find MAF adapters in that isle.
WickedWhiteDemon
Jan 10, 2016 07:17 PM
blkchr91
May 8, 2013 11:17 PM
EvoDan2004
May 19, 2008 11:56 PM
