Installed IC Piping Car Will not go into boost.
Old Mar 30, 2007 | 11:16 AM
boostfedevo's Avatar
OK I now im gonna get Flame for this one but i dont care.. I just installed Nisei IC pipe kit last night with a TiAL VTA BOV. The car idles fine but once i start to drive it doesnt wanna go past 3k rpms and it only builds about 3psi??? Do i have something unplugged that it doesnt want to go in boost?
Any suggestions would be great.
I do have a MBC and all the lines are ran to were they are suppose to go.
Old Mar 30, 2007 | 11:21 AM
Bash's Avatar
Dang idk but try taking off your mbc and putting it back to stock just to be sure then post if you still have the issue....
Old Mar 30, 2007 | 11:23 AM
newimportowner's Avatar
Sounds like a boost leak, i mean seriously you just said you replaced your IC pipes.................
Old Mar 30, 2007 | 11:24 AM
nutrulz's Avatar
Sounds a bit like a VTA Blow off valve.
Old Mar 30, 2007 | 11:25 AM
2muchboost's Avatar
sounds like my car when the uic pipe came off, but when that happened the car wouldnt move at all???
Old Mar 30, 2007 | 11:26 AM
Jasil's Avatar
You knowingly did something that decreases performane in all, but the most highly tuned cars and yet you said to yourself..."Man, that Ppsshhh sound makes me look too cool I have to have it now!! "
It sounds like a boost leak or MAF go over your steps I'm sure you will find out the culprit. R/R and call it a day.
car does move but its slooww probablly i really have trouble getting it to 30mph
Q@EvoPowerMods's Avatar
Vacuum leak maybe, I'm with the other guy...double check your connections to make sure nothing is loose or even a tiny hole/slit in vacuum line. That has to be it.
Old Mar 30, 2007 | 11:31 AM
Im gonna go back out side and check all the vacuum lines..Ive got a meeting to goto in like 1 hour and 30 mins..
Old Mar 30, 2007 | 11:42 AM
DEL TURBO's Avatar
Did you remove your intake? Maybe your MAF harness is unplugged but your idle would probably be terrible.
Old Mar 30, 2007 | 11:57 AM
I just check the lines running to the MBC and BOV and theres no slices or anything and there on good. MAF is plugged in..
When i have the car running and i rev it from under the hood everything seems fine i dont hear any leaks or feel air coming out of any of the pipes.. but when i drive around and give it gas i hear the turbo trying to spool loud..it sounds like a air leak but why wouldnt it do it when its not moving??
bboy_RES
28
Aug 12, 2007 11:23 AM
kaonashi
May 16, 2006 05:13 PM
RyanM
15
Sep 12, 2005 12:29 PM
BOOSTEZ
May 14, 2005 12:39 PM
93civEJ1
46
Mar 21, 2005 09:24 AM
