Wire Mesh over Turbo Inlet
Old Mar 30, 2007 | 02:24 PM
bioman's Avatar
Question Wire Mesh over Turbo Inlet
When I upgrade the Turbo (Gt35r), how bad is it to put just wire mesh over the turbo inlet? Instead of using the pipe and air filter. I've seen some people do this and I would think you get better airflow this way, but there is also the chance that you are sucking in hot engine air because the turbo is located right under the headers.
Thought/Opinions?
Old Mar 30, 2007 | 02:28 PM
ItalyIX's Avatar
This is assuming you are runnning a MAP system, right?
Old Mar 30, 2007 | 02:29 PM
93turbomax's Avatar
Not a very good idea!!! Dirt and other fine particles than can cause damage can still make it through there.
Old Mar 30, 2007 | 02:32 PM
rlui0514's Avatar
unless its a non-daily driver
Old Mar 30, 2007 | 03:00 PM
93turbomax's Avatar
Well if its track only go for it
Old Mar 30, 2007 | 05:18 PM
sonicnofadz's Avatar
I would advise against this, even its a track only car. If you ever wind up off roading the car (sliding off track) you might suck in some small rock particles or sand...not good.
Anthonync94
Apr 17, 2015 10:49 AM
sphinx7
Jul 24, 2014 02:00 PM
Myszkewicz
Dec 27, 2005 11:38 AM
otter
16
Aug 26, 2004 01:53 PM
