Anyone ran a Green on an IX?
Old Apr 3, 2007 | 06:15 AM
  #31
mudduck's Avatar
Originally Posted by cij911
FWIW -- I am currently hitting, on my 9, 24 psi @ ~3500 - 3600 rpm in 3rd gear from a 2000 rpm WOT run. I was concerned as I thought I should have been hitting peaking at more like 3100 rpm.
cij911, the reason your boost spike is coming on 500rpm later is most likely because of your HFC.
Take a look at the recent Dynoflash thread on a IX where the removal of the cat makes a significant difference in power and spool...
Old Apr 3, 2007 | 06:22 AM
  #32
Kee1pride's Avatar
didn't need Al to tell us that. Test pipes are just the way to go with power and spool. when I put my AMS exhaust (test pipe) on, i was caught off gaurd in first gear at how much faster it spooled.
Old Apr 3, 2007 | 07:42 AM
  #33
Noize's Avatar
EvoM Administrator
Double hump
Look at this boost graph (top graph) for verification.
See how it hits and falls then comes back? That's just a Forge UNOS on there. Stock IX turbo, stock WGA.
Old Apr 3, 2007 | 10:53 AM
  #34
cij911's Avatar
Actually I disagree Noize...I believe what you are seeing is the ~4000/4500 range MIVEC efficiency jump (VE spike) which drops boost...then at ~5000 VE comes back and boost psi returns to general taper....We have been talking about this in ECUFlash forum for a while now and folks have been addressing / resolving by increasing the MWGDC in that area...
Old Apr 3, 2007 | 11:00 AM
  #35
cij911's Avatar
I am getting the same spool with the TTP test pipe....
Old Aug 8, 2007 | 10:03 PM
  #36
PANGES's Avatar
Old thread, but for those who may care. I was around 310whp/300wtq on 91 octane and after the FP Green, I hit 326whp/319wtq. This was on a Dyno Dynamics dyno with an Evo 9. TBE/Cosworth cams/fuel upgrades/etc.
