The path to BR BB 50Trim
Old Apr 2, 2007 | 06:13 AM
recompile's Avatar
I'm avoiding meth.
So perhaps cams + headstuds, boost 23psi on a 50Trim, pump gas, no meth, maybe 425whp ???
And no other upgrades needed other than my current TBE, BR Deluxe FMIC with all piping, mini battery, and intake ???
Old Apr 2, 2007 | 06:29 AM
Creamo3's Avatar
Wondering why we haven't seen any results out of Buschur for their 50-trim kit?
Old Apr 2, 2007 | 11:13 AM
Duby's Avatar
+1 That is actually the 50trim I am debating whether to get now or not but I havn't seen any results
Originally Posted by ShamelessCookie
I'm avoiding meth.
yea that should work. I've had friends make 430 on pump w/ a 50trim but . . . I've also seen numerous people with the same #s. It's very common to see 415whp with those mods and as little as 395- it may have been on a mustang dyno though.
Old Apr 2, 2007 | 11:15 AM
Duby's Avatar
RNR BB 50 Trim / Nisei / HKS / GSC / AMS / SMC / FIC / ACT / Prostreet / LPI / APS / Dynoflash / Stillway
Best ET: 11.568 w/ 2.0 60'
Best MPH: 126.17
With that sig, I would figure you should hit 10s with a decent 60'
If you don't mind PM me the rest of your mods and exact cams.
Old Apr 2, 2007 | 11:56 AM
recompile's Avatar
Calling out to David to post some IX 50 Trim results... preferably on pump gas, no meth, and stock internals (or at the most, cams)
Old Apr 2, 2007 | 12:35 PM
Bosshog's Avatar
I think you are planning too far away. why dont you do a full bolt on stock turbo car first and see how you like it?
Get cams, intake, ported/coated stock (or good manifold like full race), fmic with licp first. You pay extra $ for manifold + cams minus Mini Battery Kit, Upper Intercooler Pipe w/ Flange and Tial 50mm Stainless Blow Off Valve. The difference in price would be close to 1k$, but I would expect around 35HP additional power
Later, if you get bored with the axed out stock turbo, you could add 20GLT + injectors and have a car that will be close to 50trim numbers on pump gas. Who knows, by 2008 they might have an improved version of 20GLT
Old Apr 2, 2007 | 12:40 PM
recompile's Avatar
I'm still not 100% sure I want cams... and if I'm getting a full turbo kit I don't want to waste money on porting/coating my manifold, O2, etc.
I'm also not sure about the 20G-9LT... I would guess that since it's bolt on I can't come close to 50 Trim as you indicate... but I dunno.
Old Apr 2, 2007 | 12:45 PM
Bosshog's Avatar
why dont you want cams?
Cams: 20HP on pump for $600
50 Trim: 80HP (guessing here) on pump for 4+k$
Old Apr 2, 2007 | 05:10 PM
David Buschur's Avatar
Every car should have at a minimum Stages 1-4 on it before a turbo kit goes on the car.
I also don't think any car should have a turbo upgrade on the stock ECU. I've had no luck making big power numbers with the stock ECU and would rather see an ECU upgrade before a turbo upgrade.
No 50 trim results as we have not sold a single kit. Biggest reason is, is the Green flows with a pound or two of the 50 trim and we recommend the Green. Bolts right on, has gone 10's. Works great on pump gas.
