Transfer Case Removal Help
Old Apr 2, 2007 | 08:21 AM
Luis@TTP's Avatar
you only have to pull the driver side shaft out its going to be harder now that its out and on the floor because its going to want to move everything around. it uses a 12 mm bolt very common on the car itself you can the dent puller or a slide hammer with a decent wieght to it and it will come out unless your one of those who twisted the internal shaft in the transfer case. in witch case if you did pull the passanger side internal shaft out and look inside the whole see if it looks like it has metal shavings or signs of it bein twisted. in witch cas you would get a long punch and put through the whole and beat it out with a hammer.
Old Apr 2, 2007 | 08:44 AM
AutobonEvo's Avatar
Man i wish you were closer id lend you my slide hammer...i have a whole kit. you screw a bolt into the shafts then put a vice grip on the end of the slidde hammer and slide the weight, comes out in one try. TRUST ME iv head todo it twice ahaha.
Old Apr 2, 2007 | 08:46 AM
AutobonEvo's Avatar
http://www.autobarn.net/xxxw-ta-81200.html here 40 bucks should get it right out.
Old Apr 2, 2007 | 11:27 AM
jdmrally's Avatar
well i work on evolutionss at the local mitsu dealership and ive pulled a transfer case off one before, but i just cant seem to get mine off
Old Apr 2, 2007 | 11:29 AM
jdmrally's Avatar
something has to be broken because i used a slide hammer and its not budging. i can get it to go further in but not out.
Old Apr 2, 2007 | 12:02 PM
AutobonEvo's Avatar
this make no sense........im stumped.
Old Apr 2, 2007 | 03:23 PM
jdmrally's Avatar
yeah im just going to take it to a shop and have it pressed out, ill probably have to end up buying another one.
Old Apr 2, 2007 | 09:42 PM
hondafan's Avatar
the shaft and the part of the TC it locks into may be parts that shep can get to rebuild your TC. i'd check with him if they're f*****. www.sheptrans.com
Old Apr 2, 2007 | 09:55 PM
lightspeed1's Avatar
Ten to one says that there is a little bit of twisted splines, and/or alot of rust or corrosion fusing the shaft in the case (sat through the winter in Missouri??).
Old Apr 3, 2007 | 05:11 AM
Luis@TTP's Avatar
ok so if it can go in but not out its not rusted in there either try turning the shaft a few times and then try the dent puller again on both sides if the passanger side can come out look through the hole in the t/c and see if it is twisted if it is then get a long punch about half inch thick and a 2 1/2 hammer and hit the punch through the hole to get it to pop out and while you are doing so continue to turn it between each hit or (while using the slide hammer.
Old Apr 3, 2007 | 01:17 PM
CO_VR4's Avatar
The slide hammer should do the trick, if you're using it right. If you decide to use a punch, make sure to find a brass round the proper diameter and use that for the punch, so that you don't mushroom the end of the shaft.
Old Apr 13, 2007 | 09:36 PM
jdmrally's Avatar
So I took it to the Mechanic and it took him 4 hours to remove it with a slide hammer, I guess apparently Mitsubishi damaged it when they removed my transmission to replace a syncro, it was bent right where the shaft enters so when i tried pulling back and forth it got wedged. Needless to say, I wasn't to happy with them and after a few minutes of arguing they gave in and ordered me a new one no charge, im putting it in tomorrow :-) Thanks for the help guys
Old Apr 14, 2007 | 12:26 PM
Mr. EvoVIII's Avatar
Hey im doing some research on how to change my clutch on my own, and i found Evo Clutch Install (joe's EVO8) on the Evo how to/ installation forum. It has some helpfull info, manual service links and all. Check it out.
Old Apr 14, 2007 | 07:25 PM
kjewer1's Avatar
**** those slidehammers. A 1 dollar hardware store U bracket with a hole drilled in it, and a M8x1.25 bolt to draw the shaft out with works the *****. I can't take the credit for it though, I learned it from a friend of mine who is a Mitsu tech.
Old Apr 14, 2007 | 07:42 PM
evolancer04's Avatar
Here you are, for all of you who plan to do a tranny pull for a clutch or something first find out what you will need and then make sure you know what you are doing.
And you tap a M8x1.25 stud into the piece that screws on the head of the slide hammer.
mclaren
Mar 16, 2012 09:05 PM
jcreager82
11
Aug 21, 2011 12:40 PM
rgonyer
Jun 29, 2010 11:29 PM
Stevo IX
27
Jan 24, 2010 05:05 PM
EVOlutionary
19
Oct 1, 2006 05:54 PM
