Has anybody put a mivec motor in a 8?
no one has anymore info on this?
difference is a hose that routes from the oil pressure sensor hole to the head. the oil pressure sensor is mounted in the oil filter housing. the 8 oil pressure sensor was on the back of the block.
"acd doesn't matter, it uses its own ecu. abs doesn't matter it's all that same.
the evo 8 block is the same as the 9 block. THIS IS A BIG ONE
this also means you can swap a 2.4 in easy.
the head and ecu are what you ahve to worry about.
if you're doin' a swap this large... you will strongly consider getting an aem ems evo 9 version. this will simplify things, although the transfer harness will be ugly"
Sound advice
But what i have seen is most people have just been selling the 8 and getting a 9RS...which is also not a bad idea.
So are the blocks the same are diff? If the blocks are the same then all we need is a complete head, engine harness, and ecu and Malibu Jack to show you how to change the immobilizer code in the ecu.
