yes another wierd noise thread...
Old Apr 2, 2007 | 08:26 PM
evrblazin's Avatar
My car just making a slight rattle sound, in second and third gear, at around 10 lbs. of boost, when accelerating and sometimes on the decel. then goes away. I hold boost just fine. any ideas what this could be? I can't tell if it's the drivetrain or not. It seems to happen at or around half to full throttle. Car is basically stock: exaust, drop in, flash, bov
Any help is appreciated...
Old Apr 2, 2007 | 08:31 PM
evrblazin's Avatar
oh and the noise just started after I swapped all of my fluids I dont know if that would cause it though.
Ph3n1x's Avatar
a bolt in ur head?
j/k
seriously it can be tonnes and tonnes of things..... Youll need to decipher based upon trial and error/.
Old Apr 2, 2007 | 08:34 PM
evrblazin's Avatar
where would you start? turbo? wastegate? Im hoping not a tranny issue all of the sudden
Old Apr 2, 2007 | 08:47 PM
Ph3n1x's Avatar
Did you take off and put on back the undertray, if so is it secure?
Old Apr 2, 2007 | 08:58 PM
evrblazin's Avatar
We took off a small section on the undertray when we flushed the coolant... I will check that... this is more of a slight metallic grind / vibration almost feels like it's under my feet but cant tell.
Old Apr 3, 2007 | 03:06 AM
ONRAILS's Avatar
Is it rpm dependent? when you press the clutch in does it stop?
Old Apr 3, 2007 | 09:50 AM
evrblazin's Avatar
^ yes it seems to be. and pushing in the clutch does make it go away...
Old Apr 3, 2007 | 04:45 PM
evrblazin's Avatar
Old Apr 3, 2007 | 04:47 PM
Silver06evo9mr's Avatar
t-case. your fuct
Old Apr 3, 2007 | 06:54 PM
steevo's Avatar
Balance shaft? Does it start around 4k rpm?
Old Apr 5, 2007 | 07:08 PM
evrblazin's Avatar
^ not around 4k rpm lower than that at like 3k 3.5k rpm. It's pissing me off. The noise happens for a second then goes away. just a very slight rubbing or grinding noise. really only happens in 2nd and 3rd gears. damnit
Old Apr 6, 2007 | 01:24 AM
evo150's Avatar
not sure if its your problem but i had the same problem and sound as you describe. after trial and error i found it was with my mechanical o2 fix (2 antifoulers) and would cause the o2 sensor to rub on the undercarriage.
Old Apr 6, 2007 | 01:36 AM
UT_Evo's Avatar
Originally Posted by Silver06evo9mr
t-case. your fuct
Glad everyone ignored this...
Is it a rattle? A rub or a grinding noise? I'm so confused and lost.
Exhaust is the first place I'd check, then check the suspension.
Old Apr 6, 2007 | 01:52 AM
redevoboy's Avatar
t-case. your fuct
I dont think its his TC. My TC is messed up, and it happens in every gear and never goes away.
