Compression Test @ altitude question
Old Apr 2, 2007 | 09:40 PM
Charlie_B's Avatar
I did a compression test this past weekend. My numbers cam up in between 141 and 145 accross the board. I live at approx 6000' above sea level. Is there some sort of correction for high altitude compression readings? I did a search and have found one qoute saying so. I just want to confirm that Im not on the low end of the reccomended values.
thx
cb
Old Apr 3, 2007 | 06:43 AM
Charlie_B's Avatar
bump
Old Apr 3, 2007 | 06:46 AM
Warrtalon's Avatar
I don't know of a correction, but mine were about the same here in Colorado Springs @ 6000'.
Old Apr 3, 2007 | 06:55 AM
JTB's Avatar
JTB
Don't worry too much. My compression came back 131/131/130/130 last year at a similar altitude. I don't burn oil and make power that is directly comparable to other cars up here with similar mods. If you are concerned you could always do a leak down.
Originally Posted by Ted B
Static cylinder pressure readings will be affected by upgrades such as cams, changes in cam timing, etc., so don't assume that they should all be equal.
Old Apr 3, 2007 | 07:00 AM
thebluesky's Avatar
+1
Old Apr 3, 2007 | 08:02 AM
03whitegsr's Avatar
Treating it as an ideal gas, you can just do an absoulte pressure correction on it.
measured compression pressure * 14.7/ / ambient pressure ~= corrected compression pressure
I would expect your local ambient pressure to be ~11.5-12 PSIA
140s seems normal for the altitude.
As usual, pay attention to how close they values are to each other and don't worry tioo much about their average value. Drop some cams in and you'll really see the numbers drop.
Old Apr 3, 2007 | 08:25 AM
Warrtalon's Avatar
Yeah, I have cams and just made sure the numbers were close as opposed to worrying about how high (or low) they all were.
Old Apr 3, 2007 | 04:22 PM
Charlie_B's Avatar
Thanks for the help guys. There was only 3-4 psi between the highest and lowest number, so I figured I was ok. But just wanted to make sure..
Thx again.
CB
Old Apr 4, 2007 | 04:00 PM
Spooldyou's Avatar
try doing a leak down test if its more then 10 % which is considered awesome, Then i would say that you need to have it cheaked out. but some people are comfortable running more up to 20% I like being in the 5% field though!
EVO 4 life
Aug 15, 2016 07:04 PM
Mitch_evo
Aug 10, 2015 05:29 PM
v8<turbo4
Jun 9, 2014 08:44 AM
bryonboals
Nov 4, 2012 06:29 PM
NRG
Aug 14, 2011 02:12 PM
