Compression Question
Old Oct 23, 2012 | 05:20 PM
bryonboals's Avatar
Just rebuilt a motor and the compression is 10:1. 1st cylinder is 170, 2nd cylinder is 200 and 3rd is 200 we did not check the 4th, because the mechanic said they all have compression so timing is good. I think that is a huge variance. Is it me or is the timing good. I rebuilt a kia motor (wifes car) and when I did a compression test they were all even.
Old Oct 27, 2012 | 10:45 AM
Boosted Tuning's Avatar
Yeah, thats more then the difference limit allowed.
Old Oct 27, 2012 | 05:27 PM
packrat's Avatar
Time to redo this test........ If the guy didn't even check #4 then how do you know if he had the throttle plate opened on the cyl #1 check?? How many miles are on the engine? Verifying cam timing is pretty easy.
Old Oct 27, 2012 | 08:54 PM
+1
A proper retest should be done.
Old Nov 2, 2012 | 01:14 PM
bryonboals's Avatar
Just Fixed the timing it was off a tooth. New reading is 1st-150,2nd-175,3er-175 & 4th-175. We will see later what the compression is after everything seals.
Old Nov 4, 2012 | 03:40 PM
bryonboals's Avatar
Just pulled the head the variance is just too high...sure enough there is a ding on the #1 piston. The dude who put on my timing belt screwed up
Old Nov 4, 2012 | 03:43 PM
bryonboals's Avatar
What does throttle plate have anything to do with compression? I think I wrote the motor is fresh
Old Nov 4, 2012 | 04:10 PM
EvocentriK's Avatar
Throttle plate open will increase the compression result (gets more air in given cranking time). If he had it shut when testing cyl 1 it could explain the the low result, however you have since said the timing was off and the piston was dented/contacted valve and this explains it. Check your valve is not bent also.
Old Nov 4, 2012 | 06:29 PM
bryonboals's Avatar
Good to know
J8dailo
Mar 1, 2017 10:08 AM
bryonboals
Aug 14, 2015 03:40 PM
DuBBzEvo27
Jun 29, 2015 10:00 PM
bambooi
Jul 14, 2013 12:52 AM
Evo3573
18
Dec 18, 2010 12:08 PM
